RNS 310
stefan2012
Has thanked: 12 ori
Been thanked: 8 ori
#46
Sâm Aug 03, 2019 3:12 pm
@07wnb, am incarcat hartile insa Romania este la nivel de strazi principale. Cred ca mai trebuie facuta o actiune care ne scapa din pacate.
07wnb
Has thanked: 36 ori
Been thanked: 96 ori
#47
Sâm Aug 03, 2019 3:21 pm
Ok, o să mai fac săpături
stefan2012
Has thanked: 12 ori
Been thanked: 8 ori
#48
Sâm Aug 03, 2019 3:26 pm
@basile27ro: Hartile respective, cred ca ma postat unde trebuie
https://www.gpszone.ro/viewtopic.php?p=36799#p36799
nel.com
Has thanked: 12 ori
Been thanked: 13 ori
#49
Mie Aug 14, 2019 12:17 pm
Incercati hartile astea
https://drive.google.com/file/d/1FhtRNw ... p=drivesdk
Copy the cryptnav directory and prod_info.txt file to the root of your SD (or microSD) card
basile27ro
Has thanked: 666 ori
Been thanked: 302 ori
#50
Mie Aug 14, 2019 1:19 pm
sunt probate de tine cred ... vad ca sunt si importate de la Nissan, ma insel???
Multumim.
nel.com
Has thanked: 12 ori
#51
Joi Aug 15, 2019 5:10 am
Probate de mine. Functioneaza perfect pe RNS 310 cu soft 03xx_unlock. Ro la nivel de strada si numar. Cu placere!
stefan2012
Has thanked: 12 ori
Been thanked: 8 ori
#52
Joi Aug 15, 2019 6:36 pm
Confirm. Hărțile funcționează cu România full. Mulțumesc!
07wnb
Has thanked: 36 ori
#53
Joi Aug 15, 2019 6:42 pm
Bravo băieți! Abia aștept să le probez. Probabil luni.
rioachim
Been thanked: 28 ori
#54
Vin Aug 16, 2019 7:37 am
Voi scrie in engleza ca sa crape fierea in unii:
The v03xx unlock image is actually a modified v0357 which can be used when starting from any version EXCEPT from 0235. If you already updated from 0235 to 0351 then you should apply the v02xx unlock image
If you have started updating from 0212/0227 or 03xx and went up to 0357, then you can apply v03xx unlock image without any issues. Actually:
- if firmware is 02xx except 0235, update to official 0351 and then apply v03xx unlock image
- if firmware is 0235, apply specific '0235 to 0351' image and then apply v02xx unlock image
- if firmware is 03xx except 0351, apply v03xx unlock image
- if firmware is 0351, then apply v02xx unlock image (which is a modified 0351 version)
Note: start without SD card inserted and if white screen is displayed after unlock image install, just insert unmodified original CD for 0357 or 0351, depending on what unlock image you used and try SD card after this.
07wnb scrie:
Mar Iul 23, 2019 12:43 pm
Firmware si unlock:https://dfiles.eu/files/te5gjlsl8
RNS 310
Ultima oară modificat Vin Aug 30, 2019 1:53 pm de către rioachim, modificat de 3 ori în total.
basile27ro
#55
Vin Aug 16, 2019 2:14 pm
in limba romana era mai sigur ... cu ceea ce ti-ai propus.
:lol: :lol: :lol:
Uglekislorod
Has thanked: 16 ori
Been thanked: 35 ori
#56
Sâm Aug 17, 2019 8:30 pm
nel.com scrie:
Bună, mulțumesc, am verificat - aceste hărți de navigare funcționează pe RNS-310 cu firmware modificat.
Verificate în Letonia, rutele sunt stabilite corect, navigarea funcționează bine, răspunsul sistemului este normal.
Vă rog să-mi spuneți unde pot citi descrierea acestei versiuni "LCN1v9"? Lista țărilor incluse în această versiune, care este zona suprafeței drumului și cât de detaliat sunt stabilite rutele către adrese specifice?
07wnb
Has thanked: 36 ori
#57
Sâm Aug 17, 2019 8:54 pm
Nu le-am probat încă, dar după "prod_info.txt" se pare că sunt de la Nissan LCN1 V9. https://images.app.goo.gl/G1dit9fizoYWDA9e6
07wnb
Has thanked: 36 ori
#58
Sâm Aug 17, 2019 8:56 pm
Pi
Has thanked: 96 ori
Been thanked: 70 ori
#59
Dum Aug 18, 2019 3:56 pm
Salut, mulțumiri tuturor celor ce au contribuit cu informații utile la acest topic.
Am instalat 03xx_unlock peste firmware 0351 si totul este ok.
Ultima oară modificat Lun Sep 30, 2019 6:35 pm de către Pi, modificat de 3 ori în total.
mad79
#60
Dum Aug 18, 2019 5:58 pm
metoda funtioneaza si la rns 315?
