lexcomputers
Has thanked: 32 ori
Been thanked: 22 ori
Mar Apr 30, 2019 2:28 pm
Va salut
pentru cine a intampinat o problema in acuratetea gps a modelelor pni va urc aici patch de firmware furnizat de fabricat pentru a corecta eroarea de calendar (anterior fix-ului veti vedea an 2099 sau 2090 in rubrica de sateliti a interfetei )
- LISTA SIMPTOME PENTRU ACEST FENOMEN
" - Majoritatea nu "te arunca" in viitor sau in trecut ci pastreaza ora spre exemplu dar schimba meridianul si apare o decalare de 12 ore ceea ce face ca GPS ul sa treaca in mod de noapte cand e miezul zilei si invers " (Daniel Cristea)
modele pni afectate - verificate de mine - in pachet aveti si instructiuni de update firmware
- L810 - http://www.girlshare.ro/3490283890.5
- L807 - http://www.girlshare.ro/3490283891.6
- L805 - http://www.girlshare.ro/3490285689
- L510 - http://www.girlshare.ro/3490283892.7
---- modele mai noi ---
- L808 - http://www.girlshare.ro/3490285690.1
- L807 PLUS - http://www.girlshare.ro/3490285690.1
MODEL CU ANDROID
- PNI S906 7 INCH - UPDATE FIRMWARE
http://www.girlshare.ro/3490290171.5 - PART 1
http://www.girlshare.ro/3490290172.6 - PART 2
------ ALTE MODELE MIORITICE ----- TESTATE DE UTILIZATORII DE PE ACEST FORUM
-SOLUTIE 2DRIVE M10 SI M10P - FIRMWARE DE L810
-SOLUTIE MYRIA 7014 SI 5063 - FIRMWARE DE L810
-SOLUTIE SERIOUX UPQ500 - FIRMWARE DE L810
- SOLUTIE WNRO SMAILO HD7 SI HD5 8GB INTERN - FIRMWARE DE L810
- SOLUTIE SMAILO HD50 8GB INTERN - FIRMWARE DE L810 - TESTAT OK !
- SOLUTIE SMAILO HD43 - FIRMWARE GENERIC POSTAT AICI PE TOPIC (testat si de mine pe 2 aparate cu rezultate pozitive) - DE @ablbd PACHET SIMPLIFICAT https://redirect.viglink.com/?format=go ... implificat
-------- ALTE MODELE --------
MIO - MODELE AFECTATE SI PATCH-URILE AFERENTE
- EDIT: 31.07.19 - 7500 LM SAU BASE MAP - SE APLICA PATCHUL OFERIT PE PAGINA MIO DE MAI JOS DAR ATENTIE ! - TREBUIE SA AIBA SOFTUL MIOMAP ORIGINAL FUNCTIONAL - NU MERGE PE CELE DEBLOCATE SI AU INSTALAT IGO PRIMO ETC PE ELE !!!
https://service.mio.com/M0100/FileReade ... glish.html
TOMTOM- toate modelele care prezinta erori localizare se pot actualiza prin tomtom home sau tomtom mydrive connect
masinile care detin navigatii tomom carminat sau carminat live - prin acelasi procedeu ca cele standalone
BLAUPUNKT
MULTUMIRI @Dan
GPS Week Rollver Fix forTP43², TP 53 Gamma CE/EU, TP 53² CE/EU, TP 55 Active CE/EU/ T/C, TP 65 Active CE/EU T/C, TP 73² CE/EU, TP 74² T/C, TP 63 CE/EU/Gamma
https://www.gpszone.ro/download/file.php?id=3277
This firmware update fixes a problem with the weekly count.
To install, the file must be unpacked and the contents copied to a Micro-SD card. Then insert the card into the device and start the device and run the update.
multumiri @Dan
Pentru Navo linkurile de mai jos:
ATENTIE: dupa aceasta operatie se va sterge TOT ce este pe aparat: toate hartile, programele si setarile!
Pentru Navo 5003-V2: https://redirect.viglink.com/?format=go ... rnover-fix
Pentru Navo 7007HD, Navo 7008HD, Navo 7008HD-V2: Navo 7008HD-V2-gps-turnover-fix
Pentru Navo 7006HD: Navo-7006HD-gps-turnover-fix . La acest model in mod normal nu se va sterge tot ce era pe aparat.
va invit aici daca se poate sa impartasiti si ce alte dispozitive ati reusit sa corectati in aceasta privinta
- rog moderatorii sa faca sticky acest post , daca se poate !
aici aveti un link care descrie un pic mai detaliat fenomenul (engleza)
https://www.wikiloc.com/forum/viewtopic ... 21&t=10276
Ultima oară modificat Joi Aug 08, 2019 9:27 am de către lexcomputers, modificat de 8 ori în total.
janek
Has thanked: 13 ori
Mar Apr 30, 2019 10:19 pm
A reusit cineva sa rezolve problema la Serioux UPQ430 sau UPQ500 ?
Dan
Has thanked: 143 ori
Been thanked: 985 ori
Mie Mai 01, 2019 8:21 am
Si un link in limba romana pentru cei ce nu inteleg fenomenul.
https://rompos.ro/index.php/ro/noutati/ ... k-rollover
lexcomputers
Has thanked: 32 ori
Joi Mai 02, 2019 9:17 am
janek scrie:
inca nu am gasit solutie pentru serioux - voi posta aici cand am o rezolvare
- serioux are suportul tehnic la depanero (niste incompetenti) fiind detinuta de dante international - EMAG
pni a luat la cunostinta problema fiind semnalati de mine si au rezolvat doar cerand ajutor la fabrica din china
sebastian88
Has thanked: 31 ori
Been thanked: 32 ori
Vin Mai 03, 2019 3:36 pm
Am studiat putin cele 3 pachete de firmware-uri de la prieteni nostri de la piatra neamt,si am gasit in arhiva pentru PNI L810 toate informatiile necesare de update pentru RTK.bin, valabil pentru Serioux upq 500/700, PILOTON M9 Plus,PNI L510,L807,MYRIA 7014, Smailo HD 7, cam astea or fost testate de mine, pachetul respectiv este doar un update, deci nu formateaza flashul intern, nu necestia rescrierea softului de navigatie.
Ultima oară modificat Dum Mai 05, 2019 8:04 pm de către sebastian88, modificat 1 dată în total.
lexcomputers
Has thanked: 32 ori
Sâm Mai 04, 2019 6:35 am
sebastian88 scrie:
Am studiat putin cele 3 pachete de firmware-uri de la prieteni nostri de la piatra neamt,si am gasit in arhiva pentru PNI L810 toate informatiile necesare de update pentru RTK.bin, valabil pentru Serioux upq 500/700, PILOTON,PNI L510,L807,MYRIA, Smailo, cam astea or fost testate de mine, pachetul respectiv este doar un update, deci nu formateaza flashul intern, nu necestia rescrierea softului de navigatie.
daca poti detalia exact ce ai reusit sa faci ar fi grozav ! ai aplicat direct patchul si la celelalte modele ?
sebastian88
Has thanked: 31 ori
Sâm Mai 04, 2019 7:52 am
Sigur ca da,merge cu acelasi procedeu pe celalalte modele,update-ul de la 810 este tot ce aveti nevoie,merge inclusiv pe 807 si 510 fara formatare flash intern!
Multumiri lu lexcomputer pentru topicul deschis pe aceasta tema!
lexcomputers
Has thanked: 32 ori
Sâm Mai 04, 2019 10:30 am
sebastian88 scrie:
BRAVO , voiam sa incerc si eu in curand acelasi experiment pe ceva gps-uri de ale mele ca sa nu brickuiesc unul de-al clientului.
Revin cu update in functie de descoperiri - o sa actualizez postul nr 1 . Succese !!
sebastian88
Has thanked: 31 ori
Sâm Mai 04, 2019 10:49 am
Iti garantez eu ca nu ai ce sa brickuiesti,am testat eu pe modelele mentionate mai sus,totul e testat si confirmat cu succes
Daniel Cristea
Been thanked: 275 ori
Sâm Mai 04, 2019 4:24 pm
Problema se manifesta diferit pe modele diferite de GPS ! Majoritatea nu "te arunca" in viitor sau in trecut ci pastreaza ora spre exemplu dar schimba meridianul si apare o decalare de 12 ore ceea ce face ca GPS ul sa treaca in mod de noapte cand e miezul zilei si invers . Alte erori se manifesta prin decalare cu 2 zile a datei GPS , unul mai ciudat a decalat cu 2h 30 min timpul real dar a pastrat meridianul corect. Problemele si rezolvarea lor vor veni de la fiecare dezvoltator de FW de pe piata precum la PNI. Spre exemplu am testat cele prezentate mai sus pe seriile mai vechi de UPQ de la Serioux tot cu proc 2531 si rezultatul este ca nu mai gasesc satelitii ! Pe Myria 5063 sau 7014 le pune pe butuci-luni voi testa si pe modele de 2Drive si UPQ500 - 700 ! Deci postati doar ce ati testat exact ca model si functioneaza ! Nu toata lumea are FW si aparate sa se joace pe ele -unii isi vor face caramizi din aparatele GPS citind de pe net ...Nu exista o singura potiune magica pt toate !
bigbear333
Been thanked: 8 ori
Dum Mai 05, 2019 4:05 pm
pni a publicat deja pe siteul lor updateul rezolvare problema data
pt l805 aveti aici
https://www.pni.ro/sistem-de-navigatie- ... itter.html
in sectiunea download la fiecare model de gps
spintilie
Been thanked: 7 ori
Mie Mai 08, 2019 5:14 pm
Pentru alte aparate cum ar fi Smailo, Myria, etc. sunt sanse sa gasim rezolvare la problema asta?
secuiu
Has thanked: 170 ori
Been thanked: 706 ori
Mie Mai 08, 2019 6:46 pm
Am descarcat si eu update-urile de mai sus fiind curios ce au schimbat ei , este vorba doar de RTK.bin, puteti folosi rtk.bin din update-urile mio pentru aparatele pe cortex A7 sau cele de la PNI iar pentru cortex A9 din romurile PNI tot ce este cu Eboot3 este cortex A9.
Utilizati lldump pentru a va extrage firmware-ul original din aparat nu uitati de partitia ascunsa ce contine meniul aparatului
4est
Been thanked: 6 ori
Joi Mai 09, 2019 7:33 am
Am facut azi un update la un PNI L807
Numai ca:
In cele din urma l-am rezolvat mai intai cu o rescriere de firmware, noroc ca am gasit pe net ca la ei pe site nu este
Apoi cu noul firmware am aplicat din nou pacth-ul si de data asta a mers
Asa ca....aveti grija, se pare ca totusi exista riscul de brick-uire pentru gps-uri PNI!
4est
Been thanked: 6 ori
Joi Mai 09, 2019 7:44 am
Înapoi la “PNI”
