skin NextGen Android & Win
irinuca
Has thanked: 2159 ori
Been thanked: 1050 ori
Lun Ian 23, 2017 1:03 pm
skin nextgen by pongo 23-01-2017
irinuca
Joi Ian 26, 2017 7:54 pm
olele39 a adaugat inca putina culoare la skin lui pongo.
doar copiati fisierul in folderul ux.
irinuca
Joi Feb 16, 2017 6:31 am
Skin iGO Nextgen by pongo+ux plugins 08.02.2017
Putina culoare adaugata de olele, doar se copiaza fisierul in folderul ux.
Florentino1
Has thanked: 55 ori
Been thanked: 236 ori
Joi Mar 02, 2017 7:26 am
Mulțumesc mult. , îmi explici mai amănunțit cum se pune Skin by PONGO și unde trebuie să îl pun ca să funcționeze. Un salut
irinuca
Joi Mar 02, 2017 11:17 am
Arhiva contine un folder Internal storage\iGO_xxx\ux .
Inlocuiesti folderul original ux cu acel folder.
Florentino1
Has thanked: 55 ori
Joi Mar 02, 2017 4:58 pm
Mulțumesc mult
irinuca
Dum Mar 19, 2017 2:36 pm
Lang NextGen 3.5 .
Am verificat ultimul skin al lui pongo si ultimul skin al lui dodobird.
Multumesc lui dodobird pentru sprijin.
irinuca
Mar Apr 25, 2017 4:02 pm
Skin_iGO_Nextgen_by_pongo+ux_plugins_2017.04.25
descarca
Arhiva contine skinul original (.7z), ttspro.zip ce trebuie suprascris peste cel din arhiva si lang .
Florentino1
Has thanked: 55 ori
Mar Apr 25, 2017 5:17 pm
irinuca scrie:Skin_iGO_Nextgen_by_pongo+ux_plugins_2017.04.25
descarca
Multumesc mult . Un salut si drumuri bune
irinuca
Mie Mai 10, 2017 3:14 pm
update skin pongo
LOGANROLY
Has thanked: 174 ori
Sâm Mai 20, 2017 7:51 am
Mulțumesc
irinuca
Lun Mai 29, 2017 9:19 am
Skin_iGO_Nextgen_by_pongo+ux_plugins_2017.05.28
irinuca
Joi Iun 01, 2017 4:31 pm
The_skin_VW_Nextgen + lang RO 3.9 descarca
[spoiler]
And so ... start with the skin the_skin_VW_Nextgen.zip.
This is the skin mod "arimi".
Almost everything is compatible, but some fundamental things have already been changed.
I'm trying to get away from discreteness in defining parameters.
This means that the sizes and proportions of images, boxes and other visual material should depend on the screen resolution and the aspect ratio of the screen.
The first step is made in this skin: the size of the "map message box" now corresponds to the Golden Section. This ratio is 8/13 for the landscape and the aspect ratio in portret.
In this regard, the parameters of boxing are changed to these relations. At the same time, a bug in the parameters that we did not notice before ... well, it turned out))
There are other changes related mainly to the functionality and sequence of loading utilities. This is an attempt to avoid collisions when resolving external links of utilities and as a result fast and conflict-free downloading.
The debugger.zip utility is now required. It performs not only the role of the debugger, but also a means of collecting statistics about contingencies.
The second is the new utility VWTripComputer.zip, created according to these rules and prompting the above changes.
Tap on the attached image activates the utility, re-tap - Deactivates. She "lies" on top of all the boxes (if before that box was just "wipe" it).
A long tap on the button will display a selection of variants of activation types. In total there are 6 of them. These are the buttons at the bottom (on the sides) of the right (top) screen.
Tap on one of the buttons to activate the corresponding mode.
All areas are active:
Clock - change to speedometer and back.
Arrival - change for the first period and back. Long there is a choice
Address - change for the first period and back. Long there is a choice
Now for limbs:
Compass:
The compass itself and the direction to the first intermediate or end point
Clock
Actually the analog clock and the time of arrival at the first intermediate or end point - "." On the limb of the clock
Speedometer:
Actually an analog speedometer and speed limit in this country ... in this place - "." On the limiter of the speedometer
At the top of the button for selecting the means of delivering your body to auto: P
Two quick action buttons in the middle of the screen:
Button to save GPS coordinates
Button to create a route to the place where you left the car
In connection with this, another utility has been modified and now we have the Chosen: Home, Work and Car (car)
Any of these can be selected as a place where you forgot your car: rofl:
To correctly display the name, delete in save / userlist / locations.txt
[/spoiler]
irinuca
Vin Iul 21, 2017 4:31 pm
vicewandel a modificat cu totul al sau skin.
Updated the entire mod iGO_Israel.rar.
Delete the entire ux folder and replace it with this one.
Many changes in different utilities.
irinuca
Joi Aug 03, 2017 12:06 pm
Lang NextGen RO 4.0 .
Am verificat ultimele skin pongo, arimi si vicewandel.
Înapoi la “iGO NextGen Android”
