Harti RNS 315
chelnov
Has thanked: 55 ori
Been thanked: 155 ori
#991
Lun Iun 10, 2019 9:30 am
ce versiune ai incercat?modificata sau originala.....ce versiune
Software fuer RNS315 Variante EU
; Erstellt am 23.01.2015 um 15:30 von fischer
; (c) 2008-2015 Technisat Digital GmbH Dresden
;SOP4 EU
; Konfigurationen: euw_dbt_kw4512 euw_dbt_kw4513 euw_kw2213 euw_kw4513 euw_d_kw2213 euw_d_kw4513 euo_d_kw2213 euo_d_kw4513 eutrk_d_kw2213 eutrk_d_kw4513 euw_hy_kw2213 euw_hy_kw4513 aus_d
3C8035279; mPa_mECC_VW_EU_1508-0418-IC502-140808.dat
3C8035279E; mPa_mECC_VW_EU_1508-0418-IC502-140808.dat
3C8035279M; mPa_mECC_VW_EU_1508-0418-IC502-140808.dat
3C8035279G; mPa_mECC_VW_EU_1508-0418-IC502-140808.dat
3C8035279L; mPa_mECC_VW_EU_1508-0418-IC502-140808.dat
3C8035279F; mPa_mECC_VW_EU_1508-0418-IC502-140808.dat
3C8035279N; mPa_mECC_VW_EU_1508-0418-IC502-140808.dat
3C8035279H; mPa_mECC_VW_EU_1508-0418-IC502-140808.dat
3C8035279P; mPa_mECC_VW_EU_1508-0418-IC502-140808.dat
3C8035279J; mPa_mECC_VW_EU_1508-0418-IC502-140808.dat
5C0035279D; mPa_mECC_VW_EU_1508-0418-IC502-140808.dat
5C0035279C; mPa_mECC_VW_EU_1508-0418-IC502-140808.dat
3C8035279K; mPa_mECC_VW_EU_1508-0418-IC502-140808.dat
;SOP4 NAR
; Konfigurationen: nar_bt nar_bt_kw4513 nar_bt_hy nar_bt_hy_kw4513 nar_bt_spare nar_bt_spare_kw4513 nar_bt_spare_hy nar_bt_spare_hy_kw4513 nar_kw2213 nar_kw4513 nar_spare_kw2213 nar_spare_kw4513 nar_hy_kw2213 nar_hy_kw4513 nar_spare_hy_kw2213 nar_spare_hy_kw4513
1K0035274F; mPa_mECC_VW_NAR_1508-0418-IC502-140808.dat
1K0035274K; mPa_mECC_VW_NAR_1508-0418-IC502-140808.dat
5C0035274D; mPa_mECC_VW_NAR_1508-0418-IC502-140808.dat
5C0035274H; mPa_mECC_VW_NAR_1508-0418-IC502-140808.dat
1K0035274G; mPa_mECC_VW_NAR_1508-0418-IC502-140808.dat
1K0035274L; mPa_mECC_VW_NAR_1508-0418-IC502-140808.dat
5C0035274E; mPa_mECC_VW_NAR_1508-0418-IC502-140808.dat
5C0035274J; mPa_mECC_VW_NAR_1508-0418-IC502-140808.dat
1K0035274H; mPa_mECC_VW_NAR_1508-0418-IC502-140808.dat
1K0035274M; mPa_mECC_VW_NAR_1508-0418-IC502-140808.dat
1K0035274J; mPa_mECC_VW_NAR_1508-0418-IC502-140808.dat
1K0035274N; mPa_mECC_VW_NAR_1508-0418-IC502-140808.dat
5C0035274F; mPa_mECC_VW_NAR_1508-0418-IC502-140808.dat
5C0035274K; mPa_mECC_VW_NAR_1508-0418-IC502-140808.dat
5C0035274G; mPa_mECC_VW_NAR_1508-0418-IC502-140808.dat
5C0035274L; mPa_mECC_VW_NAR_1508-0418-IC502-140808.dat
;SOP4 SAM
; Konfigurationen: sar_kw2213 sar_kw4513
3C8035278E; mPa_mECC_VW_SAM_1508-0418-IC502-140808.dat
3C8035278D; mPa_mECC_VW_SAM_1508-0418-IC502-140808.dat
tonyuras
Has thanked: 67 ori
Been thanked: 7 ori
#992
Lun Iun 10, 2019 10:08 am
este pentru 2014
tonyuras
Has thanked: 67 ori
Been thanked: 7 ori
#993
К00_5001_69_99_RNS_315_MJ2014
chelnov
Has thanked: 55 ori
#994
Lun Iun 10, 2019 5:45 pm
part numberul tau este inauntru...........tu ce versiune de soft ai pt update?
fecioara74
#995
Mar Iun 11, 2019 5:43 am
Buna dimineata.Ma poate ajuta si pe mine un coleg din Tg-Jiu sau Timisoara cu o actualizare la harti pe un RNS 315.Multumesc anticipat.
chelnov
Has thanked: 55 ori
#996
Mar Iun 11, 2019 6:59 pm
#fecioara74......ai BT la navi?
fecioara74
#997
Mie Iun 12, 2019 1:11 pm
#Pentru chelnov!Ajuta-ma cu "Bt la navi"????Nu stiu la ce te referi.Multumesc.
fecioara74
#998
Joi Iun 13, 2019 5:21 am
#Pentru chelnov!!!Da am BT.Scuze ca nu am inteles despre ce este vorba.
raduci
Joi Iun 13, 2019 7:04 pm
Am citit pe un alt forum ca au aparut harti noi de la Skoda pentru Amundsen, oare nu merg si pe VW?
tonyuras
Has thanked: 67 ori
Been thanked: 7 ori
#1000
Vin Iun 14, 2019 11:55 am
chelnov scrie:
Cer scuze chelnov ca nu am mai reusit sa ti raspund...am incercat tot ce inseamna soft compatibil doar ca daca bag discul la 10 secunde se restarteaza si cu el scos face la fel,practic asa a venit de afara masina cu problema asta ,,aparea sigla vw apoi dupa 10 secunde se restarta,,eu am banuit ca s a actualizat cu harta v10 si deaia se restarteaza...dupa care s a incercat un update de soft si a ramas blocat pe imaginea in care cere cd ul cu update ul de soft 0400 undeva in coltul din dreapta ecranului apare...sincer nu mai stiu ce sa fac daca bag discul porneste actualizarea dar la 10 secunde se restarteaza si o ia de la capat
Uglekislorod
Has thanked: 16 ori
Been thanked: 35 ori
#1001
Vin Iun 14, 2019 2:40 pm
raduci scrie:
De unde ai citit despre asta? NAVTEQ a produs, de asemenea, noi hărți de navigație pentru anul 2019 pentru VW, dar nimeni nu le-a împărtășit până acum.
raduci
Lun Iun 17, 2019 7:36 am
Aici: https://www.briskoda.net/forums/topic/4 ... 2019-maps/ si mai e o referire pe vwforum.ro. Din ce spun ei este necesar un card original pentru update, eu nu am asa ca nu pot testa
pelican_777
Dum Iun 30, 2019 8:11 am
Buna,
Am cumparat un VW Golf 6 (2012) - fara card pentru navigatie. ( cred ca navigatia e RNS 310 sau 315, nu stiu exact care e diferenta intre cele 2 )
Ma poate ajuta cineva cu info ce tip de card trebuie sa iau, din ce am vazut am nevoie de un 32 GB, card SDHC normal, sau Micro SDHC cu adaptor.
Si eventual cu un link pentru ultimele harti disponibile, ma intereseaza Europa + Romania
Gps_admin
Site Admin
Has thanked: 21 ori
Been thanked: 487 ori
Administrare
Mie Iul 03, 2019 7:12 am
Nu mai postati cereri de parole aici. pentru cereri parole va rog sa creati un topic separat strict pe acest subiect. Toate mesajele legate de parole vor fi sterse, multumesc.
pelican_777
Joi Iul 11, 2019 3:35 pm
pelican_777 scrie:
Buna,
Salut, are cineva ceva informatii referitor la intrebarile de mai sus ?
