Harti RNS 315
chelnov
Has thanked: 58 ori
Been thanked: 155 ori
#1051
Lun Ian 27, 2020 4:53 pm
chelnov
Has thanked: 58 ori
#1052
Lun Ian 27, 2020 4:54 pm
chelnov
Has thanked: 58 ori
#1053
nici 315 nici 510............
rioachim
Been thanked: 45 ori
#1055
Lun Ian 27, 2020 8:38 pm
10-14zile livrare, disponibile in saptamana 9. Deci peste vreo 1-2luni
chelnov
Has thanked: 58 ori
#1056
Mar Ian 28, 2020 4:56 am
Da...niste clantai.....eu zic ca tot asa au facut si in anii precedenti.......deci sa nu ne amagim cu apa chioara.....mai bine asteptam.........
chelnov
Has thanked: 58 ori
#1057
Mar Ian 28, 2020 3:27 pm
am trimis special un prieten in munchen......nici vorba sa le aiba.......deci.........?nu mai zic nimic
07wnb
Has thanked: 63 ori
Been thanked: 210 ori
#1058
Mar Feb 11, 2020 7:01 am
Revin cu informatii.
Pentru deblocare card cu""lubuntu 16.04 32bit with patched kernel for mmc (unlocking sd)"" se va da comanda:
sudo cmd42 C99A20843ED7D90B6801E49F2BC80277 hex c /dev/mmcblk0
Cardul se va debloca,se sterge fisierul ""device.id"",se blocheaza iarasi cardul si poate fi refolosit.
Testat,verificat,functional pt. cardurile cu CID modificabil.
needed: suitable card-reader with pci connection (no usb dongles)
no maps included, unlocking system only!
boot into live system. open terminal. check kernel (uname -r should give you "4.4.98-mmc).
go on with the following tools which can be found on the internet for free: sdinfo, mmc32, cmd42
get infos about a card: sudo sdinfo /dev/mmcblk0
set cid: sudo mmc32 prog_cid /dev/mmcblk0 5d53424c32424d31013917ca53010400
lock card: sudo mmc32 lock_sd /dev/mmcblk0 C99A20843ED7D90B6801E49F2BC80277
unlock card (erases the card!): sudo cmd42 "" "asc" e /dev/mmcblk0
look in "/home/" for the kernel packages (needed for installing a system)
unlock card:sudo cmd42 C99A20843ED7D90B6801E49F2BC80277 hex c /dev/mmcblk0
Cu acest lumbutu cu comanda ""sdinfo""se poate afla CID-ul cardului chiar daca acesta este blocat.Doar se introduce cardul,chiar daca nu este recunoscut,se da comanda ""sdinfo"" si aflati CID,CSD,data fabricatiei,etc.
Cred ca ar fi de folos daca cineva are un card original cu ultimele harti ,afla CID si poate obtine de la cineva parola corespunzatoare si poate face un backup pe care apoi sa il puna la dispozitia tuturor sau sa il scoata la vanzare cum se intampla de obicei.
Mihai_2018
#1059
Mar Feb 11, 2020 8:55 am
Salutare,
am nevoie de ajutor pentru RNS 315 la Cluj-Napoca.
Multumesc !
Mihai_2018
#1060
Mie Feb 12, 2020 10:28 am
Rezolvat, va multumesc tuturor pentru munca depusa !
Merci Chelnov, mare domn !
geo_nikus
Has thanked: 15 ori
#1061
Joi Feb 13, 2020 7:46 am
07wnb scrie:
Buna ziua,
Mai gasim pe undeva acest lubuntu?
07wnb
Has thanked: 63 ori
#1062
Joi Feb 13, 2020 11:06 am
Ultima oară modificat Mar Noi 10, 2020 10:37 am de către 07wnb, modificat 1 dată în total.
sabin_dummy
Has thanked: 7 ori
#1063
Dum Feb 16, 2020 12:14 pm
Salut!
Adaug pe lista calculatoarelor cu card-reader conectat corespunzator un laptop Lenovo V310-15ISK.
Multumesc pentru informatiile impartasite.
07wnb
Has thanked: 63 ori
#1064
Lun Feb 17, 2020 8:09 am
Salut,vin si eu cu o intrebare,poate de novice.Am descarcat de curios V11 West si am vazut ca au 5GB.Daca RNS 315 are doar 4GB memorie interna,cum se pot copia in memoria interna? Nu am instalat vest niciodata.
Asta de curiozitate.Poate cineva poate sa explice pt cultura generala.
Mihai_2018
#1065
Lun Feb 17, 2020 12:11 pm
La mine a functionat, dupa introducerea SD-ului, s-a sters versiunea veche si s-a rescris V11.
Minune Dumnezeiasca... !!! :))
