iGO Nextgen LUNA (Israel) 9.35.2 .153810 ( Mar 21 2019 )
- 3
Salutare! Am instalat iGO Luna 9.35.2.153810 pe o tableta Allview ax503(asta a fost bugetul), dar nu-mi deschide. Zice ca "missing or incomplete folder:/sdcard/iGO". Are vreo fierotanie lipsa, dar ce, și de unde îl iau? Mulțumesc anticipat.
- Been thanked: 4037 ori
Cred ca denumirea folderului trebuie sa fie iGO_Luna ????!!!!! Verifica.
- Has thanked: 80 ori
- Been thanked: 129 ori
@Steluscornel Ai instalat igo luna unde memorie interna sau sd card?Pt sd card trebuie sa modifici in sys.txt calea spre sd card
data_folder_name="iGO_Luna"
linked_root_list="/storage/emulated/0 /storage/MicroSD /extsd /storage/extsd0 /mnt/extsd0 /mnt/storage/extsd0 /external_sd0/mnt/sdcard/external_sd0 /mnt/external_sd0 /mnt/sdcard/external_sd /sdcard2 /sdcard /sdcard/sd /mnt/sdcard /mnt/sd /mnt /storage /mnt/extSdCard /mnt/external_sd /mnt/sdcard/external_sd /sdcard/external_sd /storage/extSdCard"
has_secondary_root=0
android_secondary_root_path="/storage/emulated/0/addons"
Fisierul igo luna pt sd card se cooiaza in sdcard/android/data/com.nng.igoprimoluna.javaclient/files
Daca nu ai com.nng.igoprimoluna.javaclient/files in sd card il creezi tu
Salutare! Mă poate ajuta și pe mine cineva,l-am instalat dar problema când dau o căutare adresă nu pot introduce nr de stradă,îmi găsește strada care o caut dar nu pot căuta și după număr,o soluție dacă mă poate ajuta cineva,mersi!
- irinuca
- Has thanked: 2829 ori
- Been thanked: 1640 ori
skin garigor 2021.03.16
Changed the logic of displaying the mini-maneuver in the second window.
Upon request, added an icon for displaying google maps on the main screen. On / Off in the advanced settings menu.
In the TTS settings, I removed the sounding of the names of congresses and directions. Not only are the names often duplicated, in the presence of the number of the congress, the TTS pronounces some kind of heresy. Now the phrase sounds something like this: "The next exit in 800 meters." Accordingly, you need to have a translation in dictionary.voice:
Next Highway exit = "Next exit"
Many other, different edits.
- irinuca
EUROleum_LUNA+.zip 1.2.6 18.03.2021-update:
-technical maintenance, many brands as "CITROËN" etc. are visible in LUNA-branding, thanks to pongo for help
-major brands for Nederland and Germany, 90% of hotels in Europe were added, thanks to vuurvlinder
branding loading skoda
- irinuca
skin wal24 2021.03.20
skin pongo 2021.03.20
- nothing new;
- some code fixes;
- removed unnecessary plugins.
- nothing new;
- some code fixes;
