skin NextGen Android & Win
irinuca
Has thanked: 1997 ori
Been thanked: 999 ori
Dum Sep 01, 2019 11:56 am
skin vicewandel 2019.09.01
1. Changes to the VWTripComputer.zip utility.
Route type information added to route overview
2. Improved data update function for informer CommonRouteWarnings.zip
3. Others
cristianyxtl
Has thanked: 42 ori
Been thanked: 82 ori
#152
Lun Sep 02, 2019 4:14 pm
Salutare ,pentru ca radarele pe Franta sa apara pe harta trebuie modificat speedcam.zip din ux
[speedcam.disabled_countries]
_FRA=x,x,x,x,x,x,x
_SUI=x,x,x,x,x,x,x
trebuie adaugate aceste linii in :speedcam.zip\ux\speedcam/plugin.ini
Pt modificare arhiva folositi WinRar 3.93
teo_teutsu
#153
Mie Sep 04, 2019 2:23 pm
salut, am o problema skin vicewandel 2019.09.01. La destinatie se reseteaza si trebuie sa pornesc igo, 2 daca pe la jumatatea traseului schimb intinerariul fata de traseul afisat de igo in momentul recalculari se blocheaza sau se opreste igo. la repornire isi reia traseul
irinuca
Vin Sep 27, 2019 7:35 am
skin vicewandel 26 09 2019
New utility google_preview.zip view places (TMC, VIA, Destination, Current) using google maps, both a map and a panorama.
Settings are available through long tapes on the button and possibly on one of the lines inside.
Panorama is not available in all places.
Added ability to view places in some utilities,.
ALL THIS WILL WORK ONLY IF YOU SET UP LuaJava TOOL .
Other
irinuca
Lun Sep 30, 2019 9:30 am
skin pongo 2019.09.30
- fixed a couple of errors;
- refused the redundant function "Load, unload plugins";
- "speedcam", changed the alert algorithm for monitoring average speed, now cameras in the zone of average speed control are also notified;
- "speedcam", TTS and "live voice acting" are configured by entries in plugin.ini
irinuca
Vin Oct 04, 2019 11:35 am
Skin vicewandel 2019.10.04
- All means of position reporting (Emergency call, SMS) have access to contacts and are configured.
- Added tools for sending your positions (current, final, intermediate or TMC) via SMS, WhatsApp, Email.
- Text of messages is generated automatically, the messenger builds a message for a specific contact and location you have selected.
- You just have to click.
- Other.
irinuca
Mar Oct 08, 2019 1:15 pm
Lang NextGen RO 6.6
gofile
1fichier
files.fm
Am verificat :
- arimi 2019.10.05
- garigor 20.09.2019
- pongo 30.09.2019
- vicewandel 04.10.2019
irinuca
Vin Oct 11, 2019 8:19 pm
skin vicewandel 2019.10.11 parola : 4pna
- Redesigned Back to car tool in my TripComputer. The choice of vehicle type is consistent with the entire system.
- Added the ability to build a route in Google according to the parameters of the existing route. Button with a long tap on the screen and the presence of a route ... in the lower left corner of the Route window in TripComputer (so far without intermediate points)
- A utility for saving navigator parameters has been added. String in the main settings. While system.ini is being saved. We'll see
- miscellaneous
skin pongo 2019.10.10
irinuca
Joi Oct 24, 2019 11:20 am
Skin vicewandel 2019.10.24.
pass : 4pna
Reanimat busolă veche în jurul cursorului.
Sunt setate culorile corecte pentru punctele cardinale.
Direcția către punctul țintă sau intermediar depinde de ce date ale punctului dvs. sunt afișate în partea stângă jos.
De asemenea, realizat cu o busolă pe butonul principal.
S-au eliminat unele rugozități.
irinuca
Joi Oct 31, 2019 7:50 pm
Skin vicewandel 2019.10.31 parola : 4pna
- On the maps (Google), a marker for the desired place appeared
- Added means of viewing the place using Google Maps in Drag Mode, on the TMC map, on the map for working with POI.
- All this with the tap on the map and using the Local Menu
- Drag Mode even displays a button
- Other
irinuca
Mar Noi 26, 2019 1:15 pm
Skin vicewandel 2019.11.26
pass : 4pna
Present:
- name builder
- the ability to transfer to different groups of POI based on cash groups at the moment
- quick button (in one click) to save favorite
Added:
- ability to control group visibility
- the ability to select by group (search)
You can hide the labels on the buttons and therefore you can control it both from sys.txt, and through the sys.txt control by
[interface]
text_on_buttons = 0
NeeK
Localitate: Undeva
Has thanked: 199 ori
Been thanked: 619 ori
#162
Sâm Dec 07, 2019 5:08 pm
Salve @irinuca
Mi-a murit fostul mobil si acum am luat un altul Samsung A70.
Astfel am instalat un alt kit iGO Israel ce functioneaza cu aceasta rezolutie si m-am apucat de a personaliza pe acesta. Mapchanger-ul a mers dar m-am blocat iarasi la skin changer cu acest lua. Am incercat in diverse feluri dar ecranul de schimbare skin-uri ramane complet gol. Nu mai am nici o idee desi am urmat pasii de mai inainte ceva nu merge bine sau imi scapa mie ceva.
Se poate un ajutor?
► Show Spoiler
irinuca
Dum Dec 08, 2019 3:21 pm
La cele de aici ar mai fi de adaugat :
In Setari Telefon - Aplicatii selectez aplicatia Lua Interpreter.
De acolo selectezi Permisiuni si activez Spatiu de stocare.
Si :
Script creaza o lista save\profiles\01\userlists\SkinList.txt in care sunt inventariate toate directoarele de tipul ux_yyyy ce contin un fisier de tip the_skin_yyyy.
Adica are un numar de intrari ( skin ) creat dinamic functie de folderele ux_yyyy existente la acel moment.
Urmareste la fiecare rulare a script fisierul indicat.
NeeK
Localitate: Undeva
#164
Dum Dec 08, 2019 4:04 pm
Super, asta a fost problema in setari telefon.
Acum merge excelent ca pe celalalt telefon.
Merci.
irinuca
Joi Dec 26, 2019 1:22 pm
Lang NextGen RO 6.7
gofile
1fichier
Verificat ultimile skin arimi, frontzosd, pongo, pongo sumsum, vicewandel.
Înapoi la “iGO NextGen Android”
