Hello
The subject is general about Becker, it has been raised many times but ...
I need BE B40 (BBF40, active 6 plus) for Becker but also 6S (BHH00), everything for TMC to work.
I have various programs and licenses, but I always have a problem with TMC.
It is also that it selects up to 100 messages, and after restarting it stops on 6-12 messages!
What is supposed to be in Resident flash, what remains from the original and what needs to be squeezed out, e.g. whether to remove from the license folder the folder .reg and device.nng and the like.
And above all, what licenses must be and which can not be (maybe they are blocking something).
thank you in advance.
I need treated software and licenses to make tmc work
Becker 6, 6s, 6sl i TMC
- Has thanked: 356 ori
- Been thanked: 101 ori
Salutare tuturor .
Am instalat acest soft Becker 6sl pe o navigatie chinezeasca no name 800x480 fara TMC , totul pare ca ruleaza bine dar nu am nicaeri butonul inapoi si de inchidere OF are cineva vreo solutie in rezilvarea acestei probleme ? .Acum plec intr o cursa la Paris ,dar vreau sa continui cu acest soft la intoarcere . Se multumeste anticipat.
