Becker active 7sl brak tmc
eauto
Has thanked: 24 ori
Been thanked: 6 ori
Mar Iul 30, 2019 8:26 am
Hello
My Becker active 7sl (BBH 41 R2, BBHOOQOB160328.con)
works but there is no TMC.
  I used all my .exe (569,447,840,005)
The program works with all exe files that I used, but I do not have tmc (radio, RDS antenna)
I've added licenses a little and much, but nothing more
Please help
ps
it's about tmc with a radio antenna, tmc online works.
yaco
Been thanked: 5 ori
Mar Iul 30, 2019 5:58 pm
So You should have original *.con file and license
BBH41*.lyc
Becker_Link2Live_Services.lyc (as I know, tmc is via wifi - internet connection only)
TMC_FIX.lyc
FIX_PKG_for_Becker_Connected_devices.lyc
Lifetime_Map_Update_Becker_UN_R50_FREE_2017_Q4.lyc
after run soft, check if the TMC message is not available
copy tmc files to: navigator/content/tmc
If everything is ok connect tmc antena and run device on battery dosconnect ftom external power
so and of Course all software must be instlled on internal memory, no sd card
eauto
Has thanked: 24 ori
Been thanked: 6 ori
Mie Iul 31, 2019 9:52 am
the use of these licenses and more, nothing changes.
shows the icon at startup, then radio waves, but does not choose
eauto
Has thanked: 24 ori
Been thanked: 6 ori
Joi Aug 01, 2019 7:43 pm
To the topic above ... problem solved.
I apologize to everyone ...
the problem was with the contact between the device and the Becker holder (exhibition device)
Tmc works on the original software after converting .exe, licenses and adding the tmc folder to content
