Poate are cineva fisieru GUPDATE.GCD pentru zumo 346 sau 396 ca e la fel , pe el nu este sa-l pot modifica
sau o varianta sa pot pune full europa deblocata
Garmin zumo 346
- Has thanked: 16 ori
- Been thanked: 377 ori
incearca sa faci update cu asta:
This is a custom SD flash kit only for HWID 3033 devices (Zumo 346-396), firmware version 3.30
https://anonfiles.com/8eTcW2r5b3/Zumo_3 ... fw3.30_rar
Instructions:
Download the RAR file from the Link attached then extract directly to a clean microSD formatted in FAT32 (best using WinRar to extract)
Ensure the device is fully OFF (not in standby), insert the card in device and power on.
"Loader" will appear on screen for some time and the device will boot up when the flash of patched firmware is complete.
The device can reboot itsself during the process.
After the Patch is applied the device will be able to read Unlocked Maps.
When the flash has completed remove the card, in its root will be a new file named 154.bin.
That's a backup of the device's non-volatile memory region and may save your device at a later date.
You would be best to keep a copy of it somewhere safe for as long as you have the device.
Instructions:
