City Navigator Europe NTU 2020.30 FID 8360
petrivulcan
Been thanked: 21 ori
Dum Ian 19, 2020 9:20 am
Apasa
tomojure
Has thanked: 44 ori
Been thanked: 42 ori
Lun Ian 20, 2020 8:48 am
jmermel
Been thanked: 118 ori
Dum Feb 02, 2020 11:35 am
[Garmin] - City Navigator Europe NTU 2020.30 UN FID 8360 [unlocked]
cojocariu48
Has thanked: 22 ori
Lun Feb 03, 2020 8:35 am
Salut pentru android care sunt fisierele care trebuie puse in map si poi.multumesc
va salut de curand mi-am luat telefon Allview X3 Soul Style si as vrea un soft bun de gps multumesc.
petrivulcan
Lun Feb 03, 2020 8:56 am
cojocariu48 scrie:
salut , aici sunt harti pt aparate Garmin, probabil te intereseaza harti pentru aparate ce folosesc IGO .
intra la sectiunea Igo si gasesti ultimele harti disponibile.
cojocariu48
Has thanked: 22 ori
Lun Feb 03, 2020 9:29 am
Garmin StreetPilot android 7 am instalat programul dar ma inurc la harti
Dan
Has thanked: 178 ori
Been thanked: 1193 ori
Vin Feb 07, 2020 8:15 am
Garmin City Europe NTU 2020.30 FULL (map unlocked, pc install, cure, additional files)
Download Full torrent: Click AICI
Multumirile merg la nuvi.
kapp007
Localitate: Buzau
Has thanked: 18 ori
Been thanked: 9 ori
Vin Feb 07, 2020 1:19 pm
Salut, unde se pun fișierele adiționale? Ar fi util un tutorial, ce aparate suporta anumite fișiere adiționale?
Dan
Mie Feb 12, 2020 11:17 am
About Garmin maps Additions files (gmap3d-JCV-gmaptz-ASR-G2S) - preluare
3D buildings (gmap3d.img)
3D buildings is rather self explanatory – the unit will superimpose a 3D image of the buildings in the vicinity of your position when the unit is in routing mode, so you can at least see/visualise the landmarks around you, rather than at present, where there is nothing to tell you whether you are 100% on the correct road/lane/street or not. The picture best illustrates this idea.
Copy it in your nuvi's \Garmin directory
or new devices in .System hidden directory
Compatibility: Nuvi 7x5 series , the 3xxx series and 2xxx series
In 3xxx and 2xxx you can put it also in sd/Map folder with its name gmap3d.img
Foursquare
Foursquare POIs
Foursquare .img
Now, when you search, the most relevant Foursquare result appears at the top of the list. It’s an easy way to discover new and popular restaurants, shops and more.
work in 2014 nuvi Advanced Series (25x9 26x9 27x9 2589 2559 2579 2599 2689 2789, and in nuvis 58, 57, 67, 68)
Foursquare Instasearch and Foursquare Map:
in new devices 25x9
Added a new map in the directory .System/Map/FoursquareMap
also added a fifth file .sid (FoursquareInstasearch)
Lane Assistant
If multiple lanes are to be encountered on your next turn, the Next Turn arrow (single arrow in the green section at the upper left) turns into multiple arrows indicating the available lanes at that junction. It is at this point when the Next Turn indicator (single arrow) turns into the Lane Assist indicator (multiple arrows). The white arrow(s) indicate the lanes you should be in to complete the maneuver while the gray arrow(s) indicate the lanes you should not be in to complete the maneuver.
Lane Assistant files are part of City Navigator .img file.
Junction view (JCV)
junction view shows the driver which lane on a multi-lane road to take after turning. As we know, modern roads have more than one lane – and being in the right lane can save your life preventing accidents.
Right on the display you will see realistic road signs with arrows showing you exactly how to navigate the exit
Some JCV compatible devices
nüvi® 3790T
nüvi® 3760T
nüvi® 3750
nüvi® 1690
nüvi® 1490T
nüvi® 1450
nüvi® 1390T
nüvi® 855
nüvi® 775T
nüvi® 765T
nüvi® 755T
3xxx and 2xxx series
To use the junction view files, drag the entire “JCV” folder into your “Garmin” folder.( x:\Garmin\JCV )
or in Garmin in a subfolder called JCV on the SD Card
or in System hidden directory in a JCV folder
ASR-files
"SRX+ASR"/Voice recognition files (Automatic Speech Recognition)
ASR files must be in .System folder in an ASR Folder
Speech recognition makes navigation safer and easier than ever. Now it’s possible to keep both hands on the wheel, tell nüvi what to do and where to go, and you’re on your way to stress-free travel.
Once activated, the user can effortlessly manipulate controls by speaking the words that correspond to buttons that are on the touchscreen display, so that almost any common task can be performed without ever touching the unit.
For the ultimate in safety, a driver at any time speak the phrase, “where am I?” and their device will display its exact latitude and longitude coordinates, the nearest address and intersection, and the closest hospitals, police stations and gas stations. Speech recognition can also be used to search for addresses as well – all hands-free, from start to finish.
G2S&.db :NüRoute technology&trafficTrends
NüRoute technology with trafficTrends historical traffic and myTrends G2S (GarminAdjacencytoSSID) and .db files
Experience nüRoute™ Technology with trafficTrends™ and myTrends™
With trafficTrends™ and myTrends™ no subscription are necessary, no added costs, your nüvi GPS just does it.
With myTrends, when you save your regular destinations in your “Favorites,” your nüvi Garmin will, over time, begin to figure out where you’re going even without your telling it! It provides time of arrival and relevant traffic information. So whether you’re driving to and from work or a regularly scheduled weekly event, your Garmin Nuvi will help you get there on time.
With trafficTrends, your nüvi Garmin GPS automatically learns daytime trends for traffic flow to improve your routes and better predict your estimated time of arrival based on time of day and day of week. And you get free trafficTrends™ updates every time you connect your device to myGarmin.
G2S Path: ".System\G2S"
trafficTrends" files .db Path: ".System\SQLite\"
for compatible devices that use traffic receivers
SID
Files are stored in 34/35xx .System/ SID and are traffic trends ,instaSearch , instaAdresses and POIs and FastRouting related
POINT ADDRESSING
Door-to-door navigation, or point addressing, is a premium map feature found on some of our automotive GPS devices.
With door-to-door navigation, addresses are given a precise location, which gives you much greater arrival accuracy.
Over 80% of the addresses in our North American maps are included in our point addressing data.
The North American versions of the following models have door-to-door navigation:
Camper/RV series
dezl series
dezlCam
LIVE 1695
LIVE 2300 series
nuvi 2200 series (excluding the nuvi 2200 model)
nuvi 2300 series (excluding the nuvi 2300 model)
nuvi 2400 series
nuvi 2405 series
nuvi 2407 series
nuvi 2408 series
nuvi 2505 series
nuvi 2507 series
nuvi 2508 series
nuvi 2509 series
nuvi 2609 series
nuvi 2707 series
nuvi 2708 series
nuvi 2709 series
nuvi 3400 series
nuvi 3500 series
nuvi 3507 series
nuvi 3508 series
nuviCam
zumo 350
zumo 390
zumo 590
Devices that are not listed above or that are preloaded with maps other than North America use logical addressing instead of point addressing.
These are sid files
Înapoi la “Harti si content Garmin”
