Rom Becker 6s BHH00
- Has thanked: 766 ori
- Been thanked: 1243 ori
Everything is ok with the device, it connects to the computer, everything works (TMC as well), the battery is charged ok, I have no charging and charging graphics and it does not turn off automatically.
the inscription under the battery reads "battery powered" even when it is charging.
You solved my problem with BHH00 (6s), could you please help me with the same problem on Becker BE B40 (active 6).victorpetroi scrie: ↑Lun Iul 20, 2020 7:43 pmYou have in the archive below everything you need to repair your device. After rewriting the firmware, copy the TC for wince to the card with the structure NNGStart / NNGStart.exe and copy the contents of the ReadOnlyFlash folder to the device.
I do not know whether to post a new topic?
- ablbd
- Has thanked: 96 ori
- Been thanked: 1439 ori
BECKER BBF40 is Active 6 LMU PLUS
Utilitare:
Yes, this is the BECKER BBF40 Active 6 LMU PLUS device
downloading 1/1 success, programming 4/4 is 11%, after removing the card it stands on the Becker activ 6 logo
I do not have access to windows, it does not connect to the computer, I uploaded it to the TC card, changed the name to navigator and nothing, it stands on the logo
victorpetroi
Moderator gave me the whole set # 4 for 6s, after the format it was windows and I could use TC to paste into ReadOnlyFlash the settings that it connected to the computer
- ady1979
- Has thanked: 567 ori
- Been thanked: 742 ori
Salutare colegi
Am si eu o problema cu un becker active 6 model
BE H00 de 6 inch
Am schimbat toch-ul și nu îl pot calibra pe cel nou
-am rescris FW ,acum sta in interfata de windows si nu am legatura la pc
_nu a cerut calibrare la inceput
daca il pornesc cu cardul in el sta la 0 %
Reactioneaza la vreun exe pe card in faza asta sa pot pune calibrare ?
S_au mai e o alta solutie sa il calibrez ?
BE H00 de 6 inch
- ady1979
Am testat ceva fw de becker
-la unele se aprinde dar e display-ul decalibrat, și NU am conexiune la pc.
-la altelele rămâne ecranul negru ,după ce rescriu firmware-ul, dar atunci AM conexiune la pc.
I-mi puteți încarca Va rog
Firmware pentru becker cu display de 6-inch ?
Poate găsesc unul care se potrivește.
Va mulțumesc.
Va mulțumesc.
Thank you, everything works .... you are great
myindigocard
jjsploit download
myindigocard
jjsploit download
Ultima oară modificat Sâm Noi 25, 2023 10:08 am de către viratyzens, modificat 1 dată în total.
- ablbd
@ady1979
Gasestit aici doua variante de rom pentru Active 6S BECKERBHH00, testeaza-le pe rand incepand cu varianta PB. Practic provin din aceeasi salvare, difera doar modul de construire a celor doua variante. Important este ca au si continutul RF2, unde este programul de conectare la usb si cel pentru on/off
Utilitare:
- ady1979
Sa încep cu ce am făcut eu:
Am luat placa de la becker BHOO
-display de BH00
-toch-ul de la becker BE B50
După testare firmware(alex1963 ,ablbd,)
Display-ul se vede ok
Toch-ul reacționează deplasat
Nu am conexiune la pc ,dar GPS-ul întra în win ce
Am butonat câteva ore (deplasat) și am reușit sa ajung în windows unde are calibrare display ,dar nu ma lasă să apăs eu în colturi pr calibrare (vezi foto)
Am testat și un exe de calibrare pe card și da același mesaj.
-display de BH00
Ultima oară modificat Vin Noi 17, 2023 5:17 pm de către ady1979, modificat 1 dată în total.
- ablbd
Este foarte greu de calibrat un touch capacitiv la un rom pe Sirf, mai ales daca touch este de la alt aparat. Teoretic intrand in calibrare ar trebui sa sesizeze atingerea cu degetul si calibrarea va fi una aproximativa, insa sigur nu va merge cu un pen capacitiv. Pentru "smecherii" gen comanda din PC ar trebui sa se conecteze in ActiveSync (serial)
Utilitare:
