Rom Becker 6s BHH00
- ablbd
- Has thanked: 96 ori
- Been thanked: 1439 ori
As far as I know BHH00 is Active 6S with capacitive touch. Use LHApp.rar and format.cfg from any package you already have. Rom update preserves UUID, so the original licences should work fine.
Utilitare:
thank you, after uploading the rom to the device, it opens to "Windows 6", what to do to open on the Becker 6s wallpaper?
starting from residentfresh ... navigator.exe, everything works fine.
It does not connect to the computer!!!. I moved the program to residetfresh from the sd card.
The upload looks like this:
ends with the word "success" then shows the upload bar, at the bottom 0% and nothing happens. after removing the card and resetting, windows 6 turns on
"Use LHApp.rar and format.cfg"???
How exactly should it be done to bring it back to the original? and it started opening "Becker wallpaper, not windows ce6"
- Has thanked: 766 ori
- Been thanked: 1241 ori
You have in the archive below everything you need to repair your device. After rewriting the firmware, copy the TC for wince to the card with the structure NNGStart / NNGStart.exe and copy the contents of the ReadOnlyFlash folder to the device.
What can I do to make it work, I have re-uploaded all the software from the beginning and I still do not have battery charging graphics and automatic shutdown. the graphic says "charging from battery" even when powered. Charging is ok.
There are two ROMs in the package you gave me, V1 and V2 there may be battery problem here? The whole package I uploaded is from Victorpetroi # 4
unfortunately there is still no "battery"
- ablbd
Battery status is only available in the navi program (original or other...). As many other devices equipped with Sirf MCU, Beckers do not have a charge indicator LED or any other indication that battery is charging, so forget about battery issue.
Utilitare:
