Probleme cursor nextgen
manole76
Has thanked: 43 ori
Been thanked: 26 ori
Lun Noi 04, 2019 6:25 pm
Salut, am o mica problema cu un nextgen instalat pe win, cu toate ca-mi vede pozitia reala, adica acel punctulet albastru cursorul nu ramane pe drum sau o ia inainte singur, repet punctuletul albastru ma vede perfect unde sunt. Are vre-o setare ca nu o gasesc sau trebuie ceva adaugat in sys. Multumesc!
manole76
Has thanked: 43 ori
Mar Noi 05, 2019 10:52 am
Dar in primo comanda in sys sa stea cursorul pe drum? Adica chiar daca gps-ul te vede sa zicem la 10-15 m in afara drumului din cauza semnalului mai prost cursorul sa ramana tot pe drum.
Has thanked: 774 ori
Been thanked: 2647 ori
Mar Noi 05, 2019 11:55 am
Urca sys-ul sa aruncam o privire.....
manole76
Has thanked: 43 ori
Mar Noi 05, 2019 9:25 pm
Este vorba de nextgen, nu prea cred ca are importanta... multumesc!
[device]
sdcard_name="SDMMC"
[naviextras]
boot_service_address="http://zippy.naviextras.com/services/index/rest"
[network]
available=0
[tmc-http]
enabled=0
profile_name="nng-igo-tmc-jci"
profile_version=2
udp.enabled=0
[tmc.src.http]
enabled=0
[debug]
skip_eula=1
max_memory=134217728
reserve_memory=4194304
cache=2097152
experimental_features=1
screenshotfilename="\captures\ffscreen_%02d.jpg"
screenshotsavecameraini=0
speedcam_enabled=1
[tts]
use_tts_lang=1
[power]
backlight_methods=0
backlight_ioctrl_function=1
backlight_device_name="BKL1:"
backlight_ioctrl_code_set_param_group=1
backlight_ioctrl_code_set1=34
backlight_ioctrl_code_set2=2
backlight_ioctrl_set_value_size=4
backlight_ioctrl_code_get_param_group=2
backlight_ioctrl_code_get1=34
backlight_ioctrl_code_get2=3
backlight_ioctrl_get_value_size=4
backlight_step=0
backlight_events= 1,2
backlight_manage_values = 1
backlight_manage_keys = 1
backlight_min = 1
backlight_max = 60
backlight_reverse = 0
backlight_methods = 0
battery_critical_limits=0
battery_low_limits=0
battery_shutdown_at=0
backlight_sync_with_os=1
update_backlight_on_ac_change=0
skip_suspend_process_all=1
skip_resume_process_all=1
[gps]
port=auto
baud=auto
set_messages=0
[rawdisplay]
driver="moya"
dpi=280
[interface]
exit_on_sd_remove_fast_always=1
show_exit=1
capture_to_jpeg=1
show_scroll_button=1
[hnr]
ignored_missing_country_ids=*
[route]
[3d]
planned_route_track_width=20
planned_route_track_contour_width=2
planned_route_contour_width=2
car_antialias_max_x=256
car_antialias_max_y=256
show_guidance_arrows=0
show_guidance_strip=1
max_pois_on_horizont="4"
max_pois="10"
3d_config]
[map]
3d_max_tiltlevel="8500"
[other]
demo_enabled=0
[sound]
pause_mp3_sooner=0
enable_waveout_based_ebp=1
waveout_based_muting_fill_value=1
sound_level_0=16383
sound_level_1=28671
sound_level_2=40959
sound_level_3=45055
sound_level_4=49151
sound_level_5=53247
sound_level_6=57343
sound_level_7=61439
sound_level_8=65535
use_method=4
used_byte_in_method=7
use_os_volume=1
os_volume=255
master_volume="255"
csv_voice_enabled=1
[tmc]
use_starter_thread=0
tmc_info_database_on=1
source="avanteq"
port="COM,5"
internal_tmc_name="avanteq"
ignore_suspend=1
ignore_resume=1
avanteq_source_used=1
hwrestart_on_acc=0
tmc_provider_name_use_old=1
tmc_provider_name=1
[modules]
ITMC_STATION_SELECTOR="TMC_STATION_SELECTOR_NULL"
IFM_STATION_CACHE ="DUMMY_TMC_STATION_CACHE"
Mie Noi 06, 2019 6:52 am
In linia [3d] modifica linia show_guidance_arrows din "0" in "1".
Sterge save inainte.
manole76
Has thanked: 43 ori
Mie Noi 06, 2019 4:50 pm
In primul rand multumesc frumos dar mai am ceva de pus la punct la el daca sti, te rog frumos. Merge acum, ramane sageata pe drum dar... drumul cu traseu este colorat portocaliu, vreau daca se poate in timp ce merg in spatele la sageata sa se stearga traseul, adica sa am inaintea sagetei portocaliu iar in spatele ei sa ramana drumul gri cum sunt toate drumurile de pe harta. Si inca o intrebare te rog frumos, daca fac un traseu pt camion si dau destinatia undeva unde are interzis ma avertizeaza si nu calculeaza traseul, cum facea primo 1, asa este normal? Ma gandeam daca poate calcula traseul la fel ca primo 2, adica sa te avertizeze de restrictii dar totusi sa calculeze traseul cu tot cu restrictii. Multumesc inca o data!
