Va rog daca ma poate ajuta cineva cu un sfat. Am un PilotOn A11SPro cu IGO MyWay si merge chiar destul de ok o singura problema care nu reusesc sa o remediez cand ma deplasez ma arata la 1 metru de autostrada isi mai revine dupa care tot asa ma arata inafara drumului. Stie cineva de unde sa fie problema?Cam asa arata .sys
► Show Spoiler
[device]
devtype_fallback_to_model=1
[android]
getdeviceid_trycount=0
fullscreen=1
tablet=0
has_physical_home_button=0
;navigation_audio_stream=4
check_for_dead_links=1
check_folders_after_rebuild=0
getdeviceid_gemini=1
[camera.roundabout]
enabled=1
centery=70
[interface]
extra_settings=1
shutdown_time=0
capture_to_jpeg=1
show_scroll_button=1
default_anim_off=0
show_tmc_eventlist=1
[rawdisplay]
force_renderer="RENDER_MOYA"
;highres=1 ; for full HD
driver="gdi"
;driver="engine"
screen_xy="auto"
[gps]
location_net=1
location_gps=1
background_navigation=1
[map_update_checker]
enabled=0
[3d]
usepolyfarroads=0
car_antialias_max_x=320
car_antialias_max_y=320
road_distance_factor=0.4
planned_route_visible_behind_mountains=1
[2d]
traffic_lights = 1
[poi]
use_multi_poi_icon=0
featured_provider="netlocalsearch.naviextras.nokia"
[poi.netlocalsearch.naviextras]
services="nokia,google"
[network]
available=1
[http]
enabled=1
[naviextras]
[services]
software_download_location="http://www.igomaps.co.il/Jquery_Report.html"
[tmc-http]
enabled=1
profile_name="nng-igo-tmc-igoworld"
profile_version=2
start=1
udp.enabled=0
dt_dl_0=60.0
dt_sleep_on_error=20
dl_on_wifi_only=0
dl_dist_0_km=10.0
[traffic.settings]
traffic_enabled=1
[tmc.src.http]
enabled="1"
[other]
demo_enabled=0
[debug]
skip_eula=1
imei="android.os.Build.SERIAL"
experimental_features=1
show_networkservices=1
screenshotfilename="captures/img_%02d.jpg"
screenshotsavecameraini=0
perf_update_autostart ="1"
[feature]
back_exit=1
back_button=1
tmc_event_coloring=1
signpost_coloring=1
[sound]
csv_voice_enabled="1"
ding_muted=0
linked_root_list="/storage/extSDCard/iGO /storage/sdcard2/iGO /sdcard2/iGO /sdcard/external_sd/iGO /ext_card/iGO /mnt/_ExternalSD/iGO /mnt/emmc/iGO /mnt/extern_sd/iGO /mnt/external_sd/iGO /mnt/exsdcard/iGO /mnt/ext_card/iGO /mnt/ext_sd/iGO /mnt/extsd/iGO /mnt/extSdCard/iGO /mnt/sdcard/_ExternalSD/iGO /mnt/sdcard/external_sd/iGO /mnt/sdcard/ExtStorages/iGO /mnt/sdcard/extStorages/SdCard/iGO /mnt/sdcard2/iGO /storage/sdcard1/iGO /storage/sdcard0/iGO /storage/iGO /sdcard/sd/iGO /mnt/sdcard-ext/iGO /mnt/sdcard/sd/iGO /mnt/sd/iGO /mnt/sdcard/iGO /mnt/iGO /sdcard/iGO /storage/sdcard1/iGO /mnt/sdcard1/iGO /mnt/ext/SdCard/iGO /storage/ext/SdCard/iGO /storage/emulated/0/iGO"
has_secondary_root=0
[modules]
IGPS_DRIVER="ANDROID_NGPS_DRIVER"
[gps.igo_connector]
position_validity=-1
restart_listening_interval=0
[3d_config]
[navigation]
gps_pos_to_road=1
autoreplan_action=AUTO
junction_view_blink_time=500
junction_view_blink_time_no_lane=500
[sound.announcer]
gps_signal_lost=0
gps_disconnected=0
[hnr]
ignored_missing_country_ids=*
[route]
[android]
fullscreen=1
tablet=0
[camera.roundabout]
enabled=1
centery=70
[interface]
extra_settings=1
shutdown_time=0
capture_to_jpeg=1
default_anim_off=0
[rawdisplay]
driver="gdi"
;driver="engine"
screen_xy="auto"
[gps]
location_net=1
location_gps=1
enabled=0
[3d]
usepolyfarroads=0
[2d]
traffic_lights = 1
[poi]
[network]
available=1
[http]
enabled=1
[naviextras]
[services]
[tmc-http]
enabled=1
profile_version=2
start=1
udp.enabled=0
dt_dl_0=60.0
dl_on_wifi_only=0
dl_dist_0_km=10.0
[traffic.settings]
traffic_enabled=1
[tmc.src.http]
enabled="1"
[other]
demo_enabled=0
[debug]
skip_eula=1
[feature]
back_exit=1
back_button=1
signpost_coloring=1
[sound]
ding_muted=0
[modules]
[gps.igo_connector]
[3d_config]
[navigation]
gps_pos_to_road=1
[sound.announcer]
gps_signal_lost=0
gps_disconnected=0
[hnr]
[route]
