IGO PRIMO CAMION FAIN +( wince)
Un Igo Primo fain care mie personal imi place cum ruleaza si ca e personalizabil un pic mai mult , are indicator de baterie , altimetru , semnal de gps , avize cu voce tts dar in limba sapniola ,se poate adauga si limba romana , avizeaza radarele cu voce doar ! nu am reusit sai dau de capat sa i activez si sunetele de aviz de camera desi am adat dis sys , poate reuseste cineva sa faca activarea si ar fi foarte ok .
Atasez niste poze.
https://mega.nz/file/0f4zRTZS#fNhwPGe-9 ... 6_RGpNUlqc
Daca poate cineva sa mi modifice cineva Sys ca eu am pus cam cum am vazut ca ar trebui sa merga avizele de radar dar nu merg , doar avizeaza cu voce tts
[device]
type="Generic_device"
[power]
powermgm_state="1"
[Main]
ShowExit=1
[interface]
show_exit=1
extra_settings=1
[3d_config]
rotated_roadsigns=1
show_guidance_arrows=1
show_guidance_strip=1
[sound]
csv_voice_enabled=1
use_method=1
queue_length=200
sound_volume=255
voice_volume=255
mute_os_key=1
ding=0
[route]
correctness=90
[warning]
speedcam_enabled=1 ;(1)
speedcam_visualtype=1 ;(1)
speedcam_soundtype=1 ;(2) 1=warn if overspeed 2=approach
speedcam_soundtype_4=2 ;
speedcam_warning=1 ;(1)
;speedcam_check_frc=1
speak_tts_only=1
speedwarn_alt_builtup_based=1 ;(0)
speedwarn_alt_limit=1 ;(0)
speedwarn_alt_tolerance=110 ;(100)
speedwarn_alt_toltype=1 ;(0) alternative tolerance type
speedwarn_tolerance=110 ;(100)
speedwarn_toltype=1 ;(0) absolute or percentage
[debug]
skip_eula=1
enable_roadshadow=1
loop_sim=1
sound_q_length=200
reserve_memory=1835008
cache=262144
[map]
auto_nightmode=1
map_mode="3D"
[tts]
tts_buffer=131072
announce_exit_directions=1
tts_logics=3
priority="HIGH"
always_say_road_names=3
announce_street_name=1
skip_exit_numbers=2
Atasez niste poze.
[device]
[power]
powermgm_state="1"
[Main]
ShowExit=1
[interface]
show_exit=1
extra_settings=1
[3d_config]
rotated_roadsigns=1
[sound]
csv_voice_enabled=1
use_method=1
queue_length=200
sound_volume=255
voice_volume=255
mute_os_key=1
ding=0
[route]
correctness=90
[warning]
speak_tts_only=1
[debug]
skip_eula=1
enable_roadshadow=1
loop_sim=1
sound_q_length=200
cache=262144
[map]
auto_nightmode=1
map_mode="3D"
[tts]
tts_buffer=131072
tts_logics=3
priority="HIGH"
skip_exit_numbers=2
Ultima oară modificat Vin Ian 26, 2024 4:29 pm de către ciripian, modificat 1 dată în total.
in sys stiti cum se modifica ca sa iasa si avizele de radar nu doar cu vocea ci si sunetul de avertizare ?
Ultima oară modificat Sâm Ian 27, 2024 7:54 am de către ciripian, modificat 1 dată în total.
am modificat loading _0 adica am sters liniuta si 0 si si am scris alt loading cu liniuta si 0 dar nu schimba interfata de pornire . . am sters ui_igo9 si tot asa porneste pune te rog un ui_igo9 modificat sa porneasca cu loading _4/ multumesc
- daniel-gabriel
- Has thanked: 981 ori
- Been thanked: 565 ori
Colegule loading.bmp trebuie și atat.Mai ai in data modifică și acolo
