iGO_Basar 64Bit by iGO TEAM
Fuctie de dispozitiv si storage card se pot incerca variantele:
data_folder_name="iGO_Basar"
has_secondary_root=1
linked_root_list="/storage/emulated/0 /storage/MicroSD /extsd /storage/extsd0 /mnt/extsd0 /mnt/storage/extsd0 /external_sd0/mnt/sdcard/external_sd0 /mnt/external_sd0 /mnt/sdcard/external_sd /sdcard2 /sdcard /sdcard/sd /mnt/sdcard /mnt/sd /mnt /storage /mnt/extSdCard /mnt/external_sd /mnt/sdcard/external_sd /sdcard/external_sd /storage/extSdCard /mnt/extern_sd"
android_secondary_root_path="/storage/ xxxx-xxxx / addons "
secondary_root="storage/xxxx-xxxx/addons"
linked_root_list="/storage/ xxxx-xxxx / iGO_Basar "
content="/storage/emulated/0/addons/content"
unde “xxxx-xxxx” se inlocuieste cu ID storage card, daca una din linii nu merge atunci fie se pune punct si virgula ; in fata ei, fie se sterge.
- irinuca
- 9
- Has thanked: 2997 ori
- Been thanked: 1792 ori
; Happy Marriage v1 - pe partitii diferite ( igo pe internal si content pe card )
; Fisierele se pun in subfoldere in : Card\iGO_content\content\
android_secondary_root_path="/storage/9091-BA5F/iGO_content"
; daca vrei sa poti schimba fizic content cu utilitatile lui Gurjon :
android_secondary_root_path="/storage/9091-BA5F/Android/data/com.gja.nav.utility/files/iGO_content"
; Happy Marriage v2 - pe aceeasi partitie
; Fisierele se pun in subfoldere in subfoldere in \iGO_content\
buildings="..\..\iGO_content\content\building"
dem="..\..\iGO_content\content\dem"
maps="..\..\iGO_content\content\map"
poi="..\..\iGO_content\content\poi"
string /storage/9091-BA5F/ este denumirea sub care e vazut card de catre Total Commander
Daca schimbi card se modifica denumirea, idem daca formatezi card sau doar redenumesti card ( Note8 -> Note 8)
Evident ca nu merge, ai pus toate liniile, am scris destul de clar ca trebuie incercate pe rand functie dispozitiv si card (ultimele linii), iar SD card xxxx-xxxc inlocuit cu ID card asa cum e vazut de dispozitiv.
Apoi vezi si postul #33 bine exemplificat si detaliat.
iesti plin de tine....imi pare rau ca am cerut ajutor aici...Gil26 scrie: ↑Mie Apr 01, 2026 8:27 amEvident ca nu merge, ai pus toate liniile, am scris destul de clar ca trebuie incercate pe rand functie dispozitiv si card (ultimele linii), iar SD card xxxx-xxxc inlocuit cu ID card asa cum e vazut de dispozitiv.
imi cer iertare pentru tot...
Ultima oară modificat Joi Apr 02, 2026 9:21 am de către gomyhay, modificat 1 dată în total.
lemax55 scrie: ↑Vin Feb 08, 2019 5:53 amInstalezi din google play aplicatia total commander si afli exact denumirea cardului.Pe card creezi un folder addons iar in acest folder trebuie sa ai folderul content.In memoria interna poti lasa lang,voice,iar pe card map,poi,dem.In sys.txt trebuie sa ai:
android_secondary_root_path="/storage/xxx/addons"
addons="/storage/xxx/addons"
Unde este marcat cu xxx trebuie sa pui denumirea cardului vazuta cu total commander.Problema deja discutata pe forum,nu era necesara deschiderea unui topic.
SAU mai poti incerca aceasta versiune
https://www.gpszone.ro/viewtopic.php?p=26420#p26420
mihaimalmazen
- 9
- Has thanked: 5 ori
- Been thanked: 10 ori
https://igotrucknavigation.wordpress.com/
Salut.Cine cunoaste parola de pe acest site de la arhive?Va multumesc
Petru-iulian
- 2
- Has thanked: 38 ori
- Been thanked: 61 ori
Imi spui si mie parola pentru sygic pack multumesc
mihaimalmazen
- 9
Salut,dar softul din prima postare e tot de la ei,cum l-ai făcut rost?
catalinanghel
- Has thanked: 9 ori
- Been thanked: 7 ori
Salutare l-am instalat dar nu vede toate adresele salvate decat cele din apropiere si usericon nu s compatibile, este vreo alternativa? Mersi.lazialul scrie: ↑Lun Sep 15, 2025 3:41 pmSalutari, atasez acest kit, l-am probat pe Samsung S25, functioneaza ok are si TMC Online si Vremea, este pregatit de o echipa din Ucraina.
Dupa installare trebuie sa dati accept la toate permisiunile.
https://www.mediafire.com/file/4snwgi0w ... r.rar/file
Parola la Sygic este atlantica2023
mihaimalmazen scrie: ↑Dum Apr 05, 2026 12:50 pmSalut,dar softul din prima postare e tot de la ei,cum l-ai făcut rost?
Am plătit, doar că atunci era versiunea de hărți 2025.Q2, acum ai versiunea Q4 și schimba parola pentru a plăti încă odată.
Este posibil că ai foarte multe adrese salvate?catalinanghel scrie: ↑Mar Apr 07, 2026 5:41 amSalutare l-am instalat dar nu vede toate adresele salvate decat cele din apropiere si usericon nu s compatibile, este vreo alternativa? Mersi.lazialul scrie: ↑Lun Sep 15, 2025 3:41 pmSalutari, atasez acest kit, l-am probat pe Samsung S25, functioneaza ok are si TMC Online si Vremea, este pregatit de o echipa din Ucraina.
Nu am avut timp să încerc uaericon dacă le încarcă corect.
catalinanghel
salut da am destule adrese salvate in jur de 500, crezi ca ar fi ceva de facut?lazialul scrie: ↑Mar Apr 07, 2026 6:11 amParola la Sygic este atlantica2023
