nina
9
Has thanked: 458 ori
Been thanked: 1626 ori
#286
Joi Apr 06, 2023 2:14 pm
ovidiuc34 scrie:
Lun Apr 03, 2023 7:46 pm
buna seara..este cineva obline? as vrea un ajutor la aceasta varianta...can intra in tunel iesie afara din program,,,ce trebuie sa modific
Încearcă să adaugi în sys
[navigation]
use_duration_for_tunnel=1
stop_at_tunnel_end=1
ovidiuc34
9
#287
Joi Apr 06, 2023 6:28 pm
am sa verific maine , dar se pare ca nu vrea...sunt in casa si dupa o perioada de timp da eroare si iese afara din navigare..dar voi vedea si in strada...oricum multumesc mult, credeam ca nu mai intra nimeni pe gpszone...
nina
9
#288
Vin Apr 07, 2023 1:57 pm
Mai încearcă cu această linie
[3d]
road_shield=1
tunnel_mode_disable=1
[3d_config]
roadsign_bitmaps=0
rotated_roadsigns=0
tunnel_mode_on_delay=-1
sau
[feature]
tunnel_guidance=0
gigi123
9
Has thanked: 22 ori
Been thanked: 12 ori
#289
Sâm Apr 08, 2023 8:30 am
in sys.txt se pun urmatoarele :
[debug]
leave_tunnel=1
enter_tunnel=1
[feature]
tunnel_guidance=0
[navigation]
use_duration_for_tunnel=0
dead_reckoning=1
dead_reckoning_duration=180000
ovidiuc34
9
#290
Mar Apr 11, 2023 6:20 pm
posibil ca atunci cand nu are semnal se inchide programul de navigare..nu stiu.... acu am pus in sys si aceste randuri si voi vedea... sys e asa
[device]
type="android"
[android]
fullscreen=1
create_sdcard_dir=0
close_keyboard_on_back=1
background_shutdown_timeout=0
check_folders_after_rebuild=0
background_navigation_enabled=1
create_sdcard_dir=0
disable_restart_after_phone_call=1
fullscreen=1
ignore_keyguard=1
navigation_audio_stream=4
[rawdisplay]
screen_xy="auto"
;dpi=120
dpi=240
;dpi=430
;dpi=480
[navigation]
dead_reckoning=1
[autorad]
detect=10
disabled=1
[interface]
save_cheksum=0
minzoom2d=15
hide_eula=1
show_glonass=1
[voice]
big_junction_prio=1
bridge_prio=2
;tunnel_prio=3
;poi_prio=4
;natural_guidance_prio=5
[sound.announcer]
gps_signal_lost=0
gps_disconnected=0
[hnr]
ignored_missing_country_ids=*
[route]
[debug]
show_big_junction=1
skip_eula=1
imei="android.os.Build.SERIAL"
leave_tunnel=1
enter_tunnel=1
screenshotsavecameraini=0
max_memory=262144000
reserve_memory=5000000
[gps]
background_navigation=1
location_log=0
location_log_filename="gpslog/LocationManager"
skip_announce_errors=1
accuracy_workaround=1
data_folder_name="iGO_Pal"
linked_root_list="/storage/emulated/0 /storage/MicroSD /extsd /storage/extsd0 /mnt/extsd0 /mnt/storage/extsd0 /external_sd0/mnt/sdcard/external_sd0 /mnt/external_sd0 /mnt/sdcard/external_sd /sdcard2 /sdcard /sdcard/sd /mnt/sdcard /mnt/sd /mnt /storage /mnt/extSdCard /mnt/external_sd /mnt/sdcard/external_sd /sdcard/external_sd /storage/extSdCard"
;has_secondary_root=1
;android_secondary_root_path="/storage/FF01-0DDD/addons"
;addons="/storage/FF01-0DDD/addons
[interface]
save_cheksum=0
maxzoom2d=6000000
minzoom2d=10
minzoom3d=10
hide_eula=1
show_demo_routes=0
show_glonass=1
[map]
3d_scale_carmodel=1
3dcarsizemin=5000
3dcarsizemax=6500
3dcarsizemul=8000
[2d]
traffic_lights=1
[3d]
planned_route_visible_behind_mountains=1
use_all_building_textures=1
road_shield=1
3d_config]
roadsign_bitmaps=0
rotated_roadsigns=0
[naviextras]
boot_service_address="http://zippy.naviextras.com/services/index/rest"
[network]
available=1
[http]
enabled=1
[tmc.src.http]
enabled="1"
[tmc-http]
enabled=1
start=1
profile_name="nng-igo-tmc-igoworld"
;profile_name="nng-igo-tmc-iphone"
;profile_name="nng-igo-tmc-jci"
;profile_name="nng-igo-tmc-russia"
profile_version=2
udp.enabled=0
dl_max_events_added=8000
[sound]
ding_muted=1
[feature]
tunnel_guidance=0
[vr]
disabled=0
[here]
show_trial_notice_onstart=0
[speedcam.disabled_countries]
_FRA=x,x,x,x,x,x,x
_SUI=x,x,x,x,x,x,x
[warning]
speedcam_maxdistance_from_road=15
speedcam_enabled=1
speedcam_warning=1
is_spoken=1
ovidiuc34
9
#291
Joi Apr 13, 2023 5:35 pm
bunaseara..deci ultimele righe pe are mi-a zs sa le pun in sys au ingreunat navigatorul , adica cand dau la pus o adresa noua trebue sa astept un pic nu raspunde imedat...dar era bun si asa daca nu iesea afara.....tot pica la intrarea n tunel
Animalu
9
#292
Sâm Apr 15, 2023 5:56 pm
Missing or incomplete folder: android _linked _root
ma poate ajuta cineva cu o informatie? orice varianta de igo folosesc imi da asta..........
danythedog78
9
Has thanked: 478 ori
Been thanked: 1032 ori
#293
Sâm Apr 15, 2023 9:46 pm
Folderul igo trebuie sa fie pus in radacina memoriei interne (langa celelalte foldere existente),nu in alt folder
Daca ai pus kitul asa si tot nu functioneaza trebuie sa mergi in setarile telefonului si sa acorzi permisiunea aplicatiei igo la locatie.
Citeste viewtopic.php?f=24&t=5579
Totul despre igo
Grasori
9
Has thanked: 36 ori
Been thanked: 8 ori
#294
Mie Mai 03, 2023 10:04 am
Buna ziua! Toata lumea
ux_truck_by_adrian Vă rugăm să introduceți din nou linkul! nu merge totusi. Am nevoie doar de o configurație de camion. Doar camion cu planificare completă a rutei! pachetul actual funcționează bine. e cam lent. există multe plugin-uri în folderul „ux”.
valdi9999
5
Been thanked: 4 ori
#295
Dum Mai 07, 2023 11:02 am
borodan
9
#296
Sâm Mai 27, 2023 7:35 am
Selectez skin easy, iar dupa 10sec il schimba. Oare din ce cauza?
Tatuatu
9
Has thanked: 100 ori
Been thanked: 33 ori
#297
Mar Iun 20, 2023 11:54 am
in mod navigate se comuta automat din vizualizare 3D in vizualizare Avion,cum pot face sa mearga doar in 3D?
iar la zoom,sa nu se ridice chiar asa sus pentru ca incepe sa sacadeze din cauza ca apar prea multe informatii.
dinu
9
#298
Lun Iun 26, 2023 6:39 pm
Am instalat programul și când îi dau să calculeze traseu rămâne blocat dacă ies din aplicație și intru iară îmi arată traseul ce e de făcu? Menționez că am șters cele cu ux
VladGabriel 2015
9
Been thanked: 6 ori
#299
Vin Iul 21, 2023 6:54 am
Buna ziua,tuturor!
Am instalat acest kit si l-am testat pe drumuri pana în Maramures si pot sa zic ca se mişca foarte fluent si este foarte precis,insa nu imi apar afisate evenimentele din trafic sau harta acestora.Va rog sa ma ajutati sa remediez aceast mic inconvenient si sa-mi spuneti ce modificari trebuie sa fac in .sys pt. a beneficia de aceaste facilitati.Mulţumesc anticipat pentru ajutor!
minc39955
#300
Lun Iul 24, 2023 3:09 pm
Se poate reface? Msf
Înapoi la “iGO NextGen”
