Eroare la inchiderea aplicatiei iGO Primo
- sanchez20
- Has thanked: 69 ori
- Been thanked: 18 ori
Salut!
Dupa ce inchid aplicatia primesc de fiecare data eroarea: <<Application Primo.exe encountered a serious error and must shut down.>>
Nu stiu cum sa interpretez continutul fisierului "crash", daca ma poate ajuta cineva:
------------------ Crash Log Begin -------------------
Current System time: "2017-05-30 15:47:16"
Build version: 9.6.5.221194
Build configuration: Product--ARCHFAM
OS version: 6.0
Uptime: 0 h 0 m 22 sec 0 msec
Memory Stats:
FreeMemory: 61 MB, 936 KB, 0 B
TotalUseableMemory: 70 MB, 0 KB, 0 B
MaxMemory: 70 MB, 0 KB, 0 B
ReservedMemory: 5 MB, 0 KB, 0 B
ActualCacheSize: 0 MB, 0 KB, 0 B
GarbageSize: 0 MB, 0 KB, 0 B
Exception: 0xc0000005
At address: 0x0054155c
Access violation reading address: 0x00000005
0x0054155c (A)
WinCE CallStack snapshot (function names unknown - map file \ResidentFlash\Primo\Primo.map not found):
0x400296f4 (A)
0x000120a4 (A)
0x0001167c (A)
0x0001182c (A)
0x00011914 (A)
0x0065de40 (A)
0x40076fa0 (A)
0x400588f4 (A)
0x40052ac4 (A)
0x4002a988 (A)
0x4002ac78 (A)
0x40052bc4 (A)
0x0054155c (A)
0x00545774 (A)
0x005456b4 (A)
0x0006a620 (A)
0x00599894 (A)
0x0059aae8 (A)
0x0065dc2c (A)
0x0065ddf4 (A)
0x0004da3c (A)
Global status:
bInFocus: 0
bMouseDown: 0
bInLogic: 0
bInRender: 0
CurrentState[128]: ExitState
GPS Pos: (26.092650,47.748577)
Camera: pos:(26.092650,47.748577) rot:3584 persp:7800 zoom:180.000000 eng=2)
------------------- Crash Log End --------------------
thanks!!
OS version: 6.0
Memory Stats:
0x0054155c (A)
0x400296f4 (A)
0x000120a4 (A)
0x0001167c (A)
0x0001182c (A)
0x00011914 (A)
0x0065de40 (A)
0x40076fa0 (A)
0x400588f4 (A)
0x40052ac4 (A)
0x4002a988 (A)
0x4002ac78 (A)
0x40052bc4 (A)
0x0054155c (A)
0x00545774 (A)
0x005456b4 (A)
0x0006a620 (A)
0x00599894 (A)
0x0059aae8 (A)
0x0065dc2c (A)
0x0065ddf4 (A)
0x0004da3c (A)
Global status:
bInFocus: 0
bMouseDown: 0
bInLogic: 0
bInRender: 0
thanks!!
- Been thanked: 4037 ori
Colegul Sanchez s-a mai discutat asta, introdu un card in slotul de card si eroarea va dispare. Mai multi colegi au incercat o explicatie si o rezolvare. Cardul a fost rezolvarea. Daca vei verifica cardul dupa pornirea iGO vei constata ca aplicatia a creat un folder Backup gol si un fisier device.nng.
Cand nu poate creea aceste doua lucruri iti da eroarea ca nu s-a inchis corect . Unii colegi au explicat ca ar fi din cauza anumitor licente.
sanchez20 scrie:Este vorba de un gps pni, aceiasi versiune am pus de proba pe un serioux si nu mai da eroare.. am sa incerc sa rulez softul de pe card. multumesc
Deci nu trebuie rulat neaparat softul de pe card ci doar sa fie bagat cardul in slot.
- sanchez20
rcv64 scrie:sanchez20 scrie:Este vorba de un gps pni, aceiasi versiune am pus de proba pe un serioux si nu mai da eroare.. am sa incerc sa rulez softul de pe card. multumesc
am inteles, multumesc ( am gasit si postul pe old.gpszone)
sanchez20 scrie:am rezolvat problema, multe fisiere licenta - nu le interpreta corect gps-ul, am mai sters din ele, le-am mai inlocuit si acum merge.
am atasat mai jos o arhiva de licente
https://ufile.io/s13vo
Am incercat si cu licentele, dar la unele aparate merge la altele nu.
- Localitate: Bucuresti
- Has thanked: 57 ori
- Been thanked: 222 ori
Pot confirma ca problema apare de la licente, indiferent daca aplicatia ruleaza de pe memoria interna sau de pe card. Rezolvarea e simpla, trebuie sa ramana in fisierul cu licente, numai cele de baza, cu care vine iGO-ul, fara licentele aferente fiecarei versiuni de harti aparute. Metoda e testata pe multiple dispozitive, iar eroarea nu mai apare si hartile functioneaza perfect si fara acele licente. Singura situatie in care este necesara utilizarea licentelor specifice fiecarei editii de harti, este in cazul dispozitivelor Becker.
Sent from my iPhone using Tapatalk
Theopsis scrie:Pot confirma ca problema apare de la licente, indiferent daca aplicatia ruleaza de pe memoria interna sau de pe card. Rezolvarea e simpla, trebuie sa ramana in fisierul cu licente, numai cele de baza, cu care vine iGO-ul, fara licentele aferente fiecarei versiuni de harti aparute. Metoda e testata pe multiple dispozitive, iar eroarea nu mai apare si hartile functioneaza perfect si fara acele licente. Singura situatie in care este necesara utilizarea licentelor specifice fiecarei editii de harti, este in cazul dispozitivelor Becker.
Multumesc colegul de observatie, voi verifica aceasta teorie. Stiam ca este vorba de licente, dar sincer nu am stat sa le iau la mana sa verific care dau aceasta eroare.
Aceiasi problema o am si eu pe un EVOLIO Hi-Speed 4 care indiferent daca are card in slot sau nu da aceasta eroare. Nu am reusit sa rezolv nici cu setul tau de licente . Culmea este ca cu iGO Next Gen nu da eroare dar se misca in „reluare” din cauza ca este cam depasit dpdv hardware.
LE. mai are si problema ca atunci cand inchid iGO din aplicatie (butonul de power off) aparatul se restarteaza.
rcv64 scrie:Theopsis scrie:Pot confirma ca problema apare de la licente, indiferent daca aplicatia ruleaza de pe memoria interna sau de pe card. Rezolvarea e simpla, trebuie sa ramana in fisierul cu licente, numai cele de baza, cu care vine iGO-ul, fara licentele aferente fiecarei versiuni de harti aparute. Metoda e testata pe multiple dispozitive, iar eroarea nu mai apare si hartile functioneaza perfect si fara acele licente. Singura situatie in care este necesara utilizarea licentelor specifice fiecarei editii de harti, este in cazul dispozitivelor Becker.
Astazi dupa amiaza mi-a intrat in atelier un Smailo HDx, dupa instalarea Primo la inchidere dadea eroarea mai sus amintita, dupa ce am sters toate licentele de map incepand cu Q1.2016 nu a mai aparut eroarea.
Deci se confirma.
onepic scrie:@rcv64 poti atasa sau urca undeva o arhiva cu ce licente ai mai lasat in folderul de licente ? Multumesc anticipat !
Astea le-am olosit eu dupa ce am sters toate licentele care incepeau cu Mega_Free_1_Year_Update.......
Repet le-am folosit pe un Smailo HDx.
O singura data,acum 2 ani,am pus la un Prestigio si licenta din pachetul de harti si-mi dadea o eroare la fiecare pornire. Dadeam O.K. si mergea. De atunci la Primo las numai licentele kitului si acelea reduse la strictul necesar. Numai anumite variante de Nextgen au nevoie de licentele hartii .
- Fişiere ataşate
- license_android.rar
- (7.55 KiB) Descărcat de 174 ori
- licenseWin.rar
- (15.87 KiB) Descărcat de 346 ori
