iGO Primo 2.4 upgrade
MartinEbg
Vin Noi 08, 2019 5:00 pm
Hello there!
Sorry for the english guys.. unfortunately I don't speak romania 'cause I'm from Sweden. :D
I have a little problem I hope someone of you might be able to help me with. I bought an old motorcycle this summer, and with the purchase I got a GPS for free. I have tried to upgrade it to the latest maps and software, but it doesn't really work.
When I connect the GPS to my laptop I find a file with the name "branding". In it, I find the following text:
<Navigation Software>="iGO Primo 2.4"
<Web Address> | <Support E-mail>="www.GPSZone.ro"
I do also find some information that I should go to naviextras.com to update the GPS, but I can not find the right branding.
I can't really say what brand the GPS are. The box says "GPS Motorcycle, easy drive easy go". But this doesn't exist?
Sorry if I have put this question in the wrong place! I would really appreciate if someone can help me. :geek:
danythedog78
Has thanked: 154 ori
Been thanked: 245 ori
Sâm Noi 09, 2019 6:35 am
i don't know what operating system it has
in gps memory there must be multiple files
put some gps image and gps content
to see what the internal memory contains where is the folder igo
can be found in the device settings ”navi path or something like that”?
daniel-gabriel
Has thanked: 86 ori
Been thanked: 25 ori
Sâm Noi 09, 2019 12:19 pm
Omul cred ca vrea sa actualizeze hartile indiferent de sistemul de operare cat timp vede branding vede si content cineva care scrie bine engleza il poate indruma daca nu spre seara am sa traduc eu
danythedog78
Sâm Noi 09, 2019 12:54 pm
Poate ai dreptate,dar din moment ce nu sti despre ce aparat este vorba nu stiu cum poti sa il ajuti.
mgmm
Localitate: braila
Has thanked: 118 ori
Been thanked: 257 ori
Sâm Noi 09, 2019 5:19 pm
MartinEbg scrie:
Hello there!
Hello,say more details for this gps....name,model,look back of device!!
...and good thing if put here image screen with the content/file of device!
You are happy?Give a like
NEXTGEN Truck
viewtopic.php?f=83&t=4370&p=46929#p46929
MartinEbg
Dum Iun 14, 2020 5:29 pm
Hello again folks! ;)
Here comes a laaaaaaaaaate response on all your answers.
Can these pictures help you to find the right place to upgrade my GPS?
danythedog78
Dum Iun 14, 2020 6:59 pm
this is the model ?
if it is ,it has android operating system,and it's easy to do :)
MartinEbg
Dum Iun 14, 2020 8:25 pm
danythedog78 scrie:
this is the model ?
It almost looks like that one. But the modell number doesn't match.
I think it's this one (model GS-4301):
[MAGNET=]www.amazon.com/EuroFone-4-3Inch-Navigat ... WNM/MAGNET]
In this case, it should be Microsoft Windows CE 6.0 as operating system.
Ultima oară modificat Lun Iun 15, 2020 9:00 am de către MartinEbg, modificat de 3 ori în total.
mgmm
Localitate: braila
Dum Iun 14, 2020 8:47 pm
please put a printscreen with the contents of the iGo folder
NEXTGEN Truck
07wnb
Has thanked: 40 ori
Been thanked: 119 ori
Lun Iun 15, 2020 5:09 am
Este Wince nu android,128MB RAM,8GB memorie interna,merge orice kit Primo,dupa interfata de pornire are sigur NaviPath.
mgmm
Localitate: braila
Lun Iun 15, 2020 5:49 am
07wnb mi-am dat seama,am vazut in poze dar nu stim ce are in folderul igo,are kitul complet si ii sugeram sa descarce cele mai noi harti sau nu are nimic si trebuie sa puna un kit.Deasta i-am spus sa faca un printscreen
NEXTGEN Truck
Marat66
Has thanked: 47 ori
Been thanked: 36 ori
Lun Iun 15, 2020 6:31 am
Acesta este EasyGO GS-4301 4.3 "Ecran tactil Wasserdicht Motorrad Există o pictogramă care indică calea către navigare, astfel încât să puteți seta orice Igo primo adecvat. Cred că nu există probleme la instalarea programului pe acesta
► Show Spoiler
MartinEbg
Lun Iun 15, 2020 8:54 am
I´ve made a video of the screen showing some of the files in the gps-unite. Some files i should show more? :)
mgmm
Localitate: braila
Lun Iun 15, 2020 9:37 am
MartinEbg scrie:
Ok,it's easy!
Download new map here
viewtopic.php?f=16&t=4144
when downloading it's complete,copy folders new MAP and POI from iGO_HERE_Europe_2019_Q4 in your gps location Igo/content
NEXTGEN Truck
MartinEbg
Mie Iun 17, 2020 8:38 am
Well, it looks like it worked perfectly. Thanks a lot! :)
Înapoi la “iGO Primo”
