Global_cfg - ultimele versiuni
vulpoiulJhon
Localitate: Târgoviște
Has thanked: 109 ori
Been thanked: 190 ori
#76
Mar Oct 30, 2018 4:24 pm
@mihaiLLL arhiva are 119 download-uri si numai tu te plîngi ca nu merge!!!!
costeld
Has thanked: 283 ori
Been thanked: 21 ori
#77
Mie Oct 31, 2018 8:19 am
Descarcarea merge perfect!
mihaiLLL
Has thanked: 11 ori
#78
Mie Oct 31, 2018 4:21 pm
il dawnlodeaza dar,.. Status:error CRASH!!!
mitica07fbf
Has thanked: 101 ori
Been thanked: 24 ori
#79
Mie Oct 31, 2018 4:37 pm
mihaiLLL scrie:
acum l-am descarcat eu si a mers,vezi sa nu iti blocheze ceva,daca iti apare cumva o casuta cu deschide apasa pe el ca nu se intampla nimik,incearca aici ca este tot ala
Ultima oară modificat Mie Oct 31, 2018 4:41 pm de către mitica07fbf, modificat 1 dată în total.
mitica07fbf
#80
Mie Oct 31, 2018 4:40 pm
global_cfg.zip
(7.84 MiB) Descărcat de 332 ori
mitica07fbf scrie:
mihaiLLL scrie:
mihaiLLL
Has thanked: 11 ori
#81
Mie Oct 31, 2018 4:48 pm
imi arata decat clear,pauza,cancel,nu si open in explorer!!!!
adineuri am tras de pe net si a deschis fara probleme
asta e,nu este problema
si chrome il gaseste periculos si nu il descarca!!!
Has thanked: 739 ori
Been thanked: 2479 ori
Mie Oct 31, 2018 7:06 pm
Incearca cu opera....acum l-am descarcat si nu a detectat nici o problema.
costeld
#83
Lun Noi 12, 2018 10:18 am
confirm ca merge download-ul!
vulpoiulJhon
#84
Joi Dec 06, 2018 12:41 pm
global_cfg v747397
global_cfg.zip
(7.84 MiB) Descărcat de 236 ori
irinuca
Has thanked: 1875 ori
Been thanked: 967 ori
Mar Dec 11, 2018 10:51 am
3D Global_cfg 747397 modified by Alain57.
Global_cfg_3D 747397 NEW concept : Primo / Nextgen by Alain57
Primo versions prior to Nextgen use the written data and picture provided by Global_cfg to display "FLAGS, DA and TMC".
All these picture are in "bmp" format.
Nextgen will only use the written data provided by Global_cfg.
The picture used by Nextgen are in "svg" format and are not in the Global_cfg.
Regarding picture of "FLAGS", Nextgen will use those found in the "data" of your installation.
The picture of "DA and TMC" are in the form of ux.
This new concept of "Global_cfg_3D" allows the display of "3D" picture for Primo but also for Nextgen.
While using the same "Global_cfg.zip".
With Nextgen, you must of course keep your ux DA and TMC, since the picture of this "Global_cfg_3D" will use the "codes" of these ux!
Aici .
firucatalin
#86
Sâm Dec 22, 2018 1:08 pm
Salut,orice fisier global.cfg copiez in igo,cand intru sa vad info despre o anumita tara,imi arata aproximativ 3 secunde tara ceruta apoi se schimba in RO...Aveti idee ce e gresit? Igo NextGen
Leey
Been thanked: 772 ori
#87
Joi Ian 10, 2019 5:08 pm
Global_cfg_748892/10.01.2019
global_cfg_748892.rar
(7.08 MiB) Descărcat de 211 ori
stephanatsea
Has thanked: 8 ori
#88
Joi Ian 10, 2019 6:15 pm
Sal. Eu am un cfg de 14.52MB. Vad variante mai mici.
Cum se face că ultimile sunt la jumătate?
victorpetroi
Has thanked: 711 ori
Been thanked: 1062 ori
Joi Ian 10, 2019 6:30 pm
Se face ca tu nu ai o versiune oficiala.
Leey
#90
Joi Ian 10, 2019 7:21 pm
3D Global_cfg 748892 modified by Alain57.
Global_cfg_Universel.part1.rar
(7.97 MiB) Descărcat de 145 ori
Global_cfg_Universel.part2.rar
(4.82 MiB) Descărcat de 139 ori
