Becker Map Pilot Europe 2022 v22
- amami
- Has thanked: 15 ori
- Been thanked: 1249 ori
Becker Map Pilot 2022 V22 Europe Map
COMPATIBLE WITH:
Becker MAP PILOT Europa use for model:
- NEW models: M054, M075, M076, M083, M084, M085, M092 and M097.
- OLD models: 9077, M013, M041, M045, M046, M050 and M051
A-Klasse (>09/2012 – <09/2015)
B-Klasse (>11/2011 – <11/2014)
C-Klasse Limousine (>03/2011 – <03/2014)
C-Klasse T-Modell (>03/2011 – <09/2014)
C-Klasse Coupé (>06/2011 – <12/2015)
CLA-Klasse Coupé (>04/2013 – <11/2014)
CLS-Klasse Coupé (>07/2012 – <09/2014)
CLS-Klasse Shooting Brake (>10/2012 – <09/2014)
E-Klasse Limousine (>07/2012 – <03/2015)
E-Klasse T-Modell (>07/2012 – <03/2015)
E-Klasse Coupé (>07/2012 – <03/2015)
E-Klasse Cabriolet (>07/2012 – <03/2015)
GL-Klasse (>12/2012 – <03/2016)
GLK-Klasse (>06/2012 – <09/2015)
M-Klasse (>11/2011 – <06/2015)
SLK-Klasse (>03/2011 – <06/2016)
Sprinter (>07/2013)
Vito (>09/2014)
VW Crafter (>11/2013)
Becker MAP PILOT Europe Map Package 2022 V22.0 Maps and Danger Spots Europe June 2022 (Current Danger Spots).
including Becker MAP PILOT Software + Danger Spots Europe June 2022
It was tested on an M054 device and works fine, but it may also work on these models:
M054, M075, M076, M083, M084, M085, M092 & M097 but you will have to test for yourself.
Instructions:
1. VERY IMPROTANT… back you all the files on the root of your device before you do anything (i.e. drag and drop all the files inside “Becker MP” drive to a safe location on your computer).
2. Once the back up is complete delete all the files from the becker device and empty your trash bin
3. Extract all the .rar files make device.xmlt readonly or lock the file if using a Mac (They were readonly or locked but winrar removed this on compression but do use winter not JDownloader.) and copy the extracted files onto the becker device without altering any other files.
4. Plug into your car and the maps should work and check the map versions in settings.
device.xml and device.xmlt Make device.xmlt readonly or lock the file if using a Mac. (They were readonly but winrar removed this on compression but do use winrar not JDownloader.)
then you can use in the car again or you can restore the device by restoring all the files you backed up earlier.
COMPATIBLE WITH:
Sprinter (>07/2013)
Vito (>09/2014)
Instructions:
- 1
se poate urca din nou va rog ? merci !
- Localitate: Bucuresti
- Has thanked: 3 ori
- Been thanked: 6 ori
Salut ! Se mai poate un update la link? Multumesc !
Nu mai trebuie ! Am rezolvat ! https://mega.nz/file/kPxHFaDK#PwFWxZKGF ... 2os8ygEDBc
Torrent : magnet:?xt=urn:btih:FA946563943045A246F27FD6F38B3675FECDFA61&dn=V22.1%20%282022-2023%29.rar&tr=udp%3a%2f%2ftracker.openbittorrent.com%3a80%2fannounce&tr=udp%3a%2f%2ftracker.opentrackr.org%3a1337%2fannounce&tr=wss%3a%2f%2flitetracker.world
Becker Map Pilot 2022/2023 V22.1 Europe Map
Sprinter (>07/2013)
Vito (>09/2014)
It was tested on an M075 device and works fine, but it may also work on these models:
Instructions:
1. VERY IMPORTANT… back you all files on the root of your device before you do anything (i.e. drag and drop all the files inside “Becker MP” drive to a safe location on your computer).
Credit ! digital-eliteboard
Sprinter (>07/2013)
Vito (>09/2014)
Instructions:
Ultima oară modificat Dum Aug 06, 2023 12:53 pm de către OptimusPrime, modificat 1 dată în total.
Am urmat toti pasii de mai sus si nu merge pe un BMP M075 . Se pare ca nu suporta rezolutia la un CLA 2014 . Am copiat toate fisierele din back-up (2017) si merge . Ma poate ajuta cineva cu o sugestie , ce as putea face sa imi functioneze ver 2022 ?
Merge si pe modelul de Becker M013? Acelasi fisier?
Doresc un raspuns cat de repede posibil.
ms!
ms!
aceiasi intrebare o am si eu dar vad ca daca pana acum nu iti a raspuns tie cineva nici mie nu cred ca imi va raspunde...Goldenskyofficial scrie: ↑Joi Aug 31, 2023 11:41 amMerge si pe modelul de Becker M013? Acelasi fisier?
ms!
- amami
Vezi că am pus versiunea v23, la aceasta este specificat cate este pentru modelele noi și pentru cele vechi.
- Has thanked: 10 ori
- Been thanked: 5 ori
Buna seara,
Daca nu mai am cardul original la un mercedes gla x 156 pot actualiza pe un card obisnuit?
- amami
Becker Map Pilot (BMP) de la mercedes nu are nici o legatura cu cardul.
Probabil ca ai alt sistem pe masina
