FORD MFD WESTERN EUROPE+TURKEY 2018
amami
Has thanked: 9 ori
Been thanked: 491 ori
Mie Mar 28, 2018 2:30 pm
A venit primavara si cu aceasta ocazie si harta noua, 2018 pentru sistemul cu display 5"
Aici de descarcat https://mega.nz/#F!ZKxBAKhR!Z4KACjn0aAKLwRCF13Extg
Compatibilitate:
B-Max-03.2013
C-Max-10.2010-05.2015
Fiesta-01.2013
Focus-10.20111-11.2014
Kuga-12.2012-09.2015
Ranger
Transit
Tourneo
Aici vedeti noua harta https://www.youtube.com/watch?v=5hVb7tJg1kQ&t=4s
Diepvriezer
Joi Mar 29, 2018 7:05 pm
this not working.... your CID or your info.txt in the map cryptnav incorrect.
the Bosch Part Number: Ford Part Number: is emty. when i try my MFD 2017 works everyting fine.
amami
Has thanked: 9 ori
Joi Mar 29, 2018 7:53 pm
When you try your MFd 2017 work fine, onright :lol:
When you try this don't work because you don't make a good copy :roll:
If you can't make a good copy it's because you don't have a compatible card, or your pc is not good to make this :o
ursuursu
Joi Mar 29, 2018 11:35 pm
buna pentru inceput vreau sa va multumesc pentru munca depusa extraordinara!
punctul 2 ar fi cum se instaleaza si care ar fi cardul compatibil pentru instalare va multumesc anticipat!
amami
Has thanked: 9 ori
Vin Mar 30, 2018 6:36 am
Salut @ursu , si tu la fel ca @Diepvriezer v-ati inscris pe acest site acum si primul mesaj este in legatura cu aceasta harta noua, 2018.
Multumesc pentru multumiri dar ai de citit foarte multe pagini pe acest forum, s-a scris de nenumarate ori ce si cum.
Diepvriezer
Vin Mar 30, 2018 11:08 am
amami scrie:
My SD card is compatible i copy succesfuly the MDF2017 and it works(Change CID)... but its not my pc or good copy maby its your files. or CID thats maby incorrect ;)
amami
Has thanked: 9 ori
Sâm Mar 31, 2018 12:25 pm
Si pentru ca o minune nu tine mai mult de citeva zile:
Am primit avertizare de la mega ca linkul cu harta a fost sters din cauza ca cineva a spus ca "se incalca regulile de copyright" :?:
Persoana in cauza fiind fodorladislav@gmail.com
chelnov
Has thanked: 54 ori
Been thanked: 124 ori
Sâm Mar 31, 2018 3:50 pm
asa se intampla cand vrei sa ajuti oamenii.....urit din partea lui fodorladislav......
janek
Has thanked: 13 ori
Lun Apr 02, 2018 4:37 am
Stie cineva de unde se poate achizitiona un card la care se poate schimba CID-ul ? Va multumesc
Madshark
Has thanked: 7 ori
Been thanked: 4 ori
Joi Apr 05, 2018 12:14 pm
Mai exista vreo sansa ca acest fisier sa mai fie uploadat ?
slyver
Been thanked: 10 ori
Lun Apr 09, 2018 7:02 pm
Salut
Dupa ceva cautare pe net si pe alte forumuri am reusit sa descarc MFD v8
cine vrea sa incerce dau drumul la un torrent
incercati
bafta
Ultima oară modificat Vin Apr 13, 2018 5:18 pm de către slyver, modificat de 5 ori în total.
redovidiu
Mar Apr 10, 2018 9:36 am
Nu exista seederi la torrent-ul de care ai pomenit. Astept de aseara, de cand ai postat. Pacat......
slyver
Mar Apr 10, 2018 10:07 am
redovidiu scrie:
Scuze sa verific in seara asta când ajung acasă în jur de ora 19
OK Incercati acum
Ultima oară modificat Joi Apr 12, 2018 7:00 pm de către slyver, modificat de 3 ori în total.
slyver
Mie Apr 11, 2018 6:40 pm
Salut
Deci fisierele din torrent sunt ok 100% le-am testat in seara asta
Singurul lucru modificati CID -ul cu
uti79
Mie Apr 18, 2018 2:19 pm
slyver scrie:
redovidiu scrie:
OK Incercati acum
Am incercat ,nu mai e valabil link-ul imi da 0b in torent.
