Instructiuni (continuare)
8.MMI will now reboot and enter EmergencyUpdate screen
- emerg_start.png (106.78 KiB) Vizualizat de 2251 ori
Please Note: The deletion and programming processes are performed several times, until all components of the MMI have been updated. Wait until the programming process is finished and the system automatically restarts. Your input is not necessary, the flash tool will begin deleting all the existing flash information in this step
9.Once the above step is completed the programming screen will appear
- emerg_end.png (97.53 KiB) Vizualizat de 2251 ori
Please note: No input is necessary from you, the update tool will perform everything automatically.
10.Once the MMI emergency update is completed, you will need to enter engineering menu to verify the version of your MMI, to do this first press Setup and Return (3G Plus use CAR and MENU) simultaneously and hold until the display changes.
