MOD Notes:
This version has been patched completely differently from previous released versions, those that had map downloading issues should not have those anymore, traffic, maps, addons and license patches are all patched differently and bypass content.info now - so don't mess with that file or you will only cause issues for no benefit. This has been tested with the latest NT and TA maps and no issues were found during testing.
Note: You need an internet connection to use this app (to download maps and files), it checks the license as soon as it's started and I have not patched that out which prevents issues with maps etc, you also need internet for traffic/fuel prices/accidents etc.
Download:
Credit to: mentaljim
SygicTruck-22.3.4(2922)-Mod-Anymap
- Has thanked: 16 ori
- Been thanked: 369 ori
incearca asa:
Trial Reset For Traffic:
After 2 weeks after your install date, your device ID will have changed at least once, if traffic doesn't display, Open sygic truck Menu/Settings/Other Settings/Reset to defaults and restart, then you will begin your two week trial period again (only needed for live traffic).
- Localitate: GB
- Been thanked: 137 ori
- Contact:
Resetare de încercare pentru trafic:
la 2 săptămâni de la data instalării, ID-ul dispozitivului se va schimba cel puțin o dată. Dacă nu este afișat trafic, deschideți meniul Sygic Truck/Setări/Alte setări/Resetați setările implicite și reporniți, după care va începe o perioadă de probă de două săptămâni. din nou (necesar doar pentru traficul live).
