;non standard values with special handling
[RuntimeSettings]
m_strAppTitle=Sygic Truck Navigation
m_strAppHomepage=
http://www.sygic.com/
;set to restrict FPS to 10-90% of potential FPS
m_lProcessorUsage=10
;Hodnota Brandname sa do footprint.info premietne ako model=GTnav
;m_strAppBrandName=Sygic Truck
;m_strAppSwVersion=13.1.0
; Define custom splash screen
m_strAppSplash=none
;m_strAppSplashOrder=C,TL,TC,TR,BL,BC,BR
;m_strAppSplashBgr=#C0C0C0
; m_bAppTopMost=1 -> no other application will appear above navigation
; m_bAppTopMost=0 -> other applications (e.g. MP3 player) can be displayed above navigation window
m_bAppTopMost=1
; Other values read by code:
;colorMode
;cpu
;m_lAppCache
;splash
;sdcard
m_strDrvDevice=imei
m_strDefCom=GPS,9600,3
;m_strDefTmc
;m_bRouteExportEnabled=0
m_bSetRouteComp=1
;m_bPrefferRightTurn=1
;m_nPrefferRightTurn=-1
;m_lSetDpi=192
;Ballance ratio between DPI and Screen size (0% - 100%).
;if m_lSetBallanceRatio=0, DPI is ignored and Screen size has full weight.
;if m_lSetBallanceRatio=100, Screen size is ignored and DPI has full weight.
m_lSetBallanceRatio=30
; Enable/disables Dynamic contols
m_bSetDynamicList=1
m_bSetDynamicMenu=1
; In case of multiple platforms, when sharing of Resources is required.
; Path to folder with resources (GpsLogs, Icons, Itinerary, Skin, Sounds, Voices)
m_strSetResourcePath=/../Res
; Path to folder with Maps
m_strSetMapPath=/../Maps
; Path to folder with Content Informations (content.info, content.lic, footprint.info)
m_strSetContentPath=/../Maps
;select *.lang file from Skin folder
m_strSetLanguage=autodetect
m_bSetLanguageAsk=0
;select folder name from Voices folder
m_strSetVoice=autodetect
m_bSetVoiceAsk=0
m_bSetUnitAsk=0
;battery managment option in frw
m_bSetBatteryManagementAsk=0
;if true, temperature, time, coords will be set based on units
m_bSetQuickWizard=0
m_bSetTemperatureAsk=0
m_bSetTimeAsk=0
m_bSetCoordsAsk=0
m_bSetUserGuidesAsk=0
m_bSetShowUserDetail=1
;m_bSetShowUserDetailMapMyIndia=1
;use combination of digits
;1=ROMAN 2=CYRILLIC 3=GREEK 4=ARABIC 5=HEBREW 6=THAI 7=JAPANESE 8=CHINESE 9=KOREAN
m_lSetKeybList=1
m_bSetKeybListAsk=0
;select one of QWERTY, QWERTZ or AZERTY
m_strSetKeybTypeRoman=QWERTY
;select one of RUSSIAN, SERBIAN or BULGARIAN
m_strSetKeybTypeCyrillic=RUSSIAN
;select one of UAE or FARSI
m_strSetKeybTypeArabic=UAE
;select one of PINYIN, ZHUYIN, HANDWRITE or NONE
m_strSetKeybTypeChinese=PINYIN
;online settings
m_bSetOnlineAsk=0
m_bSetUpdatesAsk=0
; map report web link
m_strNavteqMapReportLink=
http://mapreporter.navteq.com/whitelabe ... itude=%LON%
;m_strNavteqMapReportLink=
http://mapreporter.navteq.com/whitelabe ... L&tabs=off
m_strTomtomMapReportLink=
http://www.mapsharetool.com/external-if ... Id=2014193
m_strMapReportUrl_TT=
https://api.api-system.tomtom.com/mit/v ... 4CQJ2xRaDK
m_bSetShowSafetyMsg=0
; System timezone (GMT + timezone = your domestic time), specify time shift in minutes (e.g. -180 for GMT-3h)
; Used for time synchronization
; Enter one of the values from Skin\timezone.ini
m_strSetTimezone=+01:00_a
; hasClock=1 (The device does have internal clock source, default) | 0 (compute clock from GPS GMT time and specified timezone)
m_bSetHasClock=1
; mouseTolerance (number of points the user can move without invoking mousemove)
m_lSetMouseToleranceMenu=25
m_lSetMouseToleranceList=15
m_lSetMouseToleranceText=15
m_lSetMouseToleranceNavi=25
;m_lSetUpdate
;m_dbSetRecommendedRam
m_bSetInternet=1
;m_strSetMeteo
;m_bSetAutosync
;m_strSetSpeedWarnSound
;m_bSetSpeedWarnVibrate
;m_strSetRailwaySound
;m_bSetRailwayWarnVibrate
;m_strSetRadarWarnSound
;m_bSetRadarsWarnVibrate
;m_bDefSpeedAlert
;m_bSetShowEula
;if set to true, battery sign will be displayed in status bar, battery management in menu will be enabled (default:true)
;m_bHasBattery=0
;if disabled, travel book will be hidden in the menu (default:1)
;;m_bTravelbook=0
;if disabled, city guides will be hidden in the menu (default:0)
;m_bSetCityGuides=1
; Set TTS modul
; Path to the Nuance modul
; Type 1 - Nuance; 2 - Acapela; 3 - Loquendo
; Format:LH= 0,SAMPAUCL = 1,IPA = 2,Nuance= 3,StarRecSAMPA= 4
m_nTtsType=1
;ScreenShotMode
;m_bSetScreenShotMode=1
;Sets a sandbox server script (none, master, testing, stable) - default none
;m_strSetSandboxServer=master
;Popup
m_bHideTeaser=0
;array of enabled teasers (RatingTeaser = 1, TrafficTeaser = 2, ScreenSaverTeaser = 3, LastDestinationTeaser = 4,
;LowFuelTeaser = 5, FtsTeaser = 6, ScoutComputeTeaser = 7, AfterComputeTeaser = 8)
;this setting is overriden by m_bHideTeaser
m_arrShowTeaser=1,2,4,5,6,7,8
;using full CJK font
m_bFullCJKfont=FALSE
;sets the behavior of back button in Android (default: exit)
;onBackBtn=minimize | disable | exit
;draw menus with OpenGL on Android (default:0)
;m_bForce3DBlit=0
;Screen saver on highways
;m_nScreenSaver=-1 (Always Ask, default) | 0 (Off) | 1 (On)
;m_nScreenSaver=-1
;Screen saver timeout in miliseconds
m_dwScreenSaverTimeout=10000
;Back button to switch to custom application
;m_strBackButton=package.name
m_strTruckParams=0.3 0.3 0.3 0.35 0.375 0.4 0.45 0.5 0.55 0.65 0.8 1
m_strRCPenalizationParams=1 1 1 0.98 0.95 1 1 1 0.95 0.8 1 1 0.95 0.85 0.8 1 1 0.98 0.95 0.9 1 1 0.95 0.8 0.7 1 0.98 0.9 0.75 0.6
;standard values
[RootSettings]
; allow user guides pdf in settings menu and at first run wizard
m_bUserGuides=0
; product identifier for product-server requests
;m_strPartnerID=SEI1
; product activation type
;m_bInitialAction=1
[ApplicationSettings]
m_bMapChange=1
m_bMySygic=1
;m_bProductActivate=1
m_bMapAlwaysProceed=1
; defines trial expire message type 1-4
m_nExpireInfoIndex=1
;set acceptable speed camera distance from road - needed for Australia region
;by default it is 10
;m_nSpeedCamMinDistance=40
;if set to 1 quick menu will be enabled (default:1)
;m_bQuickMenu=1
;if set to 1, navigation for pedestrian will be enabled (default:1)
;m_bPedestrian=0
;distance to show instruction vs. follow route
m_lInstructionDistance=5000
m_lInstructionDistanceUS=8100
; Allows to edit itinerary in Route options (default: 1)
;m_bAllowItineraryEdit=1
;allows offline optimization of current route
m_strSygicOptAccount=offline
[UnitSettings]
;select one of kilometer or yard for km, miles_yards or miles_feets
m_eDistanceUnits=UnitSettings::UnitsAutodetect
;select one of celsius or fahrenheit
m_eTemperatureUnits=UnitSettings::TempCelsius
;select one of europe, us or uk
m_eClockFormat=UnitSettings::ClockEurope
;select one of degrees, minutes or seconds
m_eGPSUnits=UnitSettings::GpsDegrees
[ViewSettings]
;select coordinates for first run of Browse map
;Latitude in deggrees: Zero = Equator, +90 = North Pole, -90 South Pole
;Longitude in degrees: Zero is Greenwich + East, - West,+180 = -180 = International date line
;m_ptViewCenter=+49.0,+21.23
;Initial zoom level on Browse map, e.g. 45000000 for Globe view
m_nViewZoom=45000000
[OnlineSettings]
m_eShopMode=OnlineSettings::ShopInapp
;m_bShowMySygicAfterUpdate=1
;m_bLoginAfterStart=1
;m_bRoamingEnabled=0
;m_eConnectionAsk=OnlineSettings::AskAlways
; Hodnota timeru pri automatickych syncoch s cloudom
m_nAutoSyncTimer = 300000
m_bUseSSL=0
m_strDrivingClientID=com.sygic.truck
[DisplaySettings]
;townblocks mode (auto,on,off) - auto is default
m_eTownblocksMode=DisplaySettings::TownBlocksAuto
;set view size ( font size )
;values: XSMALL,SMALL, NORMAL, LARGE, XLARGE
;m_nViewSizeIndex=CLowGrx::vsNormal;
;Comunity Lang settings (default:0)
m_bSetComunityLang=1
;if set to 1, speed cameras warnings will be enabled (important to switch off for countries with prohibited speed cameras) (default:1)
;m_bRadars=0
m_bFullscreen=1
m_bDataCounter=0
;Next Street info x meters before junction
m_nNextStreet=950
;Finish in Next Street
m_nNextStreetFinish=100
[HardwareSettings]
;set if app will run in background (default:0)
m_bSetBackgroundRun=1
[TruckSettings]
[PlanningSettings]
m_ETollcostVehicleSettings=PlanningSettings::Truck
m_bComputeAlternatives=1
[FeaturesSettings]
m_bSideBar=1
[SoundSettings]
m_bUseBluetoothHfp=1
m_nBluetoothHfpDelay=3000
