kornclub
speego by Avmap
Mar Ian 03, 2017 7:22 pm
i lost sd card and i wonder how can i use it with any available system tomtom or igo any advice ?
kornclub
Re: I have speego by Avmap
Joi Ian 05, 2017 10:28 am
ajutor cu Gps speego by Avmap , system windows 5 ce core
Joi Ian 05, 2017 3:57 pm
Daca memoria flash arata asa https://postimg.org/image/62bpru659/
puteti pune in flash o interfata si igo primo pe card
Joi Ian 05, 2017 10:09 pm
@kornclub the folder is copied to the card
kornclub
Mar Ian 10, 2017 2:08 pm
lemax55 scrie:@kornclub the folder is copied to the card
Multumesc foarte mult
kornclub
Mar Ian 10, 2017 2:58 pm
în cazul în care pentru a găsi România hartă
kornclub
Mar Ian 10, 2017 3:01 pm
when i click on navigator say your map files outdated please visit your local dealer
Mar Ian 10, 2017 10:07 pm
Change licenses and delete folder save
kornclub
Mie Ian 11, 2017 8:19 am
i changed licenses and replaced the folder but the same message , your map files are outdated please visit your local dealer
Mie Ian 11, 2017 8:31 am
What map are you using?
kornclub
Mie Ian 11, 2017 9:24 am
i didn`t use anything yet , i only added your files
kornclub
Mie Ian 11, 2017 9:29 am
lemax55 scrie:What map are you using?
I added the downloaded folder on both card and sd , i replaced license
kornclub
Mie Ian 11, 2017 9:38 am
If i have no chance to make it work like GPS can i make Mp3 player to work
Mie Ian 11, 2017 9:46 am
Find maps here
http://www.gpszone.ro/viewtopic.php?p=4#p4
What map you need?
kornclub
Mie Ian 11, 2017 9:49 am
I have some maps but i don`t know if it is working or how to add them
Romania_NNG_2014.03_140411.fbl
Romania_NNG_2014.03_140411_(AP).fpa
Romania_NNG_2014.03_140411.poi
Romania_NNG_2014.03_140411_(DA).fda
